Rear axle. V6 vs 4cyl
Old Jun 20, 2016 | 04:52 PM
az1320's Avatar
I see alot of people saying this gear set is a 4.88 v6 gear set for a toyota 8". My question is is there a real diffrence between the v6 and the 4cyl so long as they are both 8" rear axles?
Old Jun 20, 2016 | 05:17 PM
millball's Avatar
You got just a gear set or a 3rd member??
Toyota factory 4.88 gears use a special punkin where the pinion has a different offset from the ring gear than other punkins have.
Because of this, the OEM 4.88 ring gear is thinner than all other factory ring gears.
Only factory 4.88s can go in this punkin, and they can't go in any other. The ring gear carrier itself is the same as other 8" carriers.
There are aftermarket 4.88s' that can fit in any old 8" punkin.
V6 carriers are usually 4 pinion versis 2 pinion carriers on 4 cyls.
See this page:
http://home.4x4wire.com/erik/diffs/
Old Jun 20, 2016 | 07:03 PM
az1320's Avatar
So what I want to do is.......
I have a 88 sr5 pickup. I bought a 4.88 ifs whole assembly from a 94 4-runner. I would like to find a 4.88 3rd member to just drop into the rear axle and not have to set up a new gear set.
The 4.88 3rd members I find say v6 so I was wondering if it would go into my 88 4cyl pickup.
Old Jun 20, 2016 | 07:07 PM
millball's Avatar
They will fit no problem.
Bolt up and axle spline count all the same.
A bit stronger than 4cyl type, so thats a plus.
tbone95runner
May 31, 2016 02:24 AM
msane99
May 18, 2016 04:45 AM
Washi
May 10, 2016 12:38 PM
ToyotaMD
Apr 28, 2016 05:01 AM
byron4
May 2, 2005 11:35 AM
