Rear Axle Seal/Bearing Job
Old Jan 28, 2016 | 06:45 AM
jbaldo's Avatar
I am finishing up replacing the rear wheel bearing and seals on my 87 Pickup. I picked up a new O Ring to install too - the one that goes around the end of the axle housing. I am wondering if I should also put some RTV around the rim or should that be avoided? Is the O-Ring sufficient? I didn't have any leaks previously, but can't tell if the factory added any gasket maker during assembly? Thanks a lot for any advice!
Old Jan 28, 2016 | 07:47 AM
arlindsay1992's Avatar
If you see any rust/pitting where the O-ring contacts the axle housing or the bearing pocket a skiff of RTV isn't a bad idea. It's probably not a bad idea either way. If you have clean surfaces then a good amount of grease would be a good alternative.
Old Jan 28, 2016 | 08:45 AM
jbaldo's Avatar
Thanks. Oh I've got rust! I appreciate the advice. Thanks again
btu44
Oct 7, 2016 08:03 AM
BattleWagonActual
Dec 26, 2015 05:30 PM
Elow007
7
Dec 4, 2015 02:12 PM
Matt McLellan
Nov 29, 2015 05:57 PM
Superwhitetaco14
Nov 16, 2015 04:30 PM
