real quick -- benefits of AISIN, WARN, etc manual hubs?
Old Dec 3, 2007 | 05:30 PM
reyna12's Avatar
hey,
just as the title says--
I did a little searching but didn't find an answer. (plenty of install/question threads)
What are the benefits of aftermarket manual hubs?
Are the OEM ones just not strong enough? If so, why do they need to be so strong?
I'm sure there's a quick easy answer.
Thanks!
Old Dec 3, 2007 | 05:37 PM
bigt's Avatar
with add your cvs are always in use or rolling with manual locking hubs they are only in use when locked
Old Dec 3, 2007 | 05:40 PM
reyna12's Avatar
Okay. I know that.
But why would someone with manual locking hubs wanna change them out to another brand?
Old Dec 3, 2007 | 05:42 PM
bigt's Avatar
aisin are acutally stronger than warn.. i dont think you would want to unless you are using a different axle
Old Dec 3, 2007 | 05:49 PM
MMA_Alex's Avatar
they wouldnt. most of these trucks came with add, hence the swap threads
Old Dec 3, 2007 | 06:02 PM
RustBucket's Avatar
I don't think there is any benefit to using anything other than the Aisins. The Warns sort of look cool, but then again not really. People on the boards here don't really talk about Aisin hubs ever breaking, they only get sticky sometimes if water gets in them or whatever.
Old Dec 3, 2007 | 06:03 PM
jfreisner's Avatar
you get better flex, travel, and speedometer readings.
Old Dec 3, 2007 | 06:07 PM
Tacoma750's Avatar
search
Old Dec 3, 2007 | 06:18 PM
95RunnerSR5's Avatar
the warn's and other brands also stick out further from the wheel than the aisin's do, which may make them prone to rock damage
Old Dec 3, 2007 | 06:26 PM
notanymore's Avatar
auto hubs arnt as reaiable as manual hubs either, they have issues with not engaging sometimes.
Old Dec 3, 2007 | 06:30 PM
reyna12's Avatar
thanks, I think you're the only one who actually answered my question.
just to remind everyone...
why would someone with OEM manual locking hubs wanna change them to an aftermarket brand?
Old Dec 3, 2007 | 06:55 PM
paxil4x4's Avatar
Drama Queen/Banned
Because being a brand whore is a way of life.
Old Dec 3, 2007 | 06:56 PM
sdstud212001's Avatar
Is this really true?
Old Dec 3, 2007 | 06:57 PM
MMA_Alex's Avatar
very few of these trucks (older ones only) have auto hubs. add, and auto hubs are something totally different. with add the halfshafts are connected to the wheel, and turn all the time
Old Dec 3, 2007 | 07:12 PM
Jay351's Avatar
I remember some people saying, the reason they switched to warns is that they would rather have the hub break rather then a r&p.
Other then that, and possibly cost issues to replace a busted aisin, there really isnt a reason to switch.
Aisins are better then any other hub available to toyota's but being so strong can be a downfall if you are running a very tall r&p like a 5.71 gear.
hope that helps.
Old Dec 3, 2007 | 07:22 PM
Matt16's Avatar
I didn't read what the others wrote, but here goes. Aisin manual hubs were supplied by Toyota on all vehicles with manual hubs as opposed to Automatic Disconnecting Differential or the infamous Auto Hubs.
Aisin hubs are the strongest hubs available according to everything I've read, but they are more expensive new than others. The solution to this is to go to a junk yard or look on ebay/craigslist/yotatech classifieds for a used pair and rebuild them. By rebuild, I mean clean out the old grease, replace the gaskets and lube it back up. This way you can get THE BEST hubs available for less than $100 (I got mine for $70) and to my knowledge, hubs really wear out.
Old Dec 3, 2007 | 07:49 PM
jfreisner's Avatar
Does zebra have stripes?
Old Dec 3, 2007 | 07:51 PM
Jay351's Avatar
Getting more flex, and better speedo readings makes no sence.
When flexing you are usually offroad, where you are usually in 4wd thus hubs locked THUS the same as having ADD flanges..
im sorry but im calling that one out...
Old Dec 3, 2007 | 08:14 PM
notanymore's Avatar
only if you keep your blinker fluid filled up properly
im with jay351 on this one, i call bs on the whole spedo reading and such.
Old Dec 3, 2007 | 08:27 PM
jfreisner's Avatar
I was jk bro. What I said was complete BS.
