Random squeak?
Old Jan 21, 2013 | 04:07 PM
Edionne13's Avatar
Random squeak?
Did my IFS 4 inch suspension life 6k ago and I'm now hearing a random squeak from some bolt in the front of the passenger side I'm just wondering what bolt I should check and crank down on.
Old Jan 21, 2013 | 06:31 PM
TNRabbit's Avatar
A squeak is TOUGH to track down.....good luck!
Old Jan 21, 2013 | 07:29 PM
Xeo's Avatar
Xeo
Double check whatever bolts you had to remove and re-install for the lift, look for any marks indicating that a bolt is moving up and down or side to side (should have some sort of wear around the area.) Or just get some wd-40 and spray each bolt one by one until it goes away then bam you've found your culprit lol. OR you can just re-tighten every bolt on the lift.
Old Jan 21, 2013 | 08:21 PM
Edionne13's Avatar
Well I guess ill crank on every bolt to make sure they're secure. So nothing just falls off and I crash to my death
Edionne13's Avatar
Hmm bump stop ... Now I'm pondering
Old Jan 22, 2013 | 12:37 PM
Jake_D's Avatar
have some rock the truck back and forth to make the sound and then stick your head in the wheel well and listen for it
Old Jan 22, 2013 | 04:14 PM
Edionne13's Avatar
You sir are genius!
nvwiggins
13
Jun 16, 2016 03:05 PM
shredder4286
Oct 1, 2015 01:09 PM
tazman1972
11
Sep 28, 2015 10:32 PM
Shagool22
Sep 28, 2015 07:53 PM
Gutted91
Sep 17, 2015 05:44 PM
