Radiator Interchangeability
Old Apr 12, 2010 | 10:37 AM
YFZsandrider's Avatar
Will a radiator from a 2nd gen pickup with a 20R work in a '94 pickup with 22RE... neither have AC.
Old Apr 12, 2010 | 03:58 PM
Flash319's Avatar
The difference is rear ABS to none ABS as well as auto to manual naturally not AC. The ABS rads are mounted higher (clear abs lines) so an older rad will hit the ABS power steering lines.
Old Apr 12, 2010 | 05:13 PM
So, should my '94 have ABS?! its a 22re extra cab.
Old Apr 12, 2010 | 06:39 PM
hilandfrog's Avatar
I was hoping that the OP was asking if a 89 V-6 runner 3 core rad would fit in a 94 22re truck.
Because that is my question....
repo
Old Apr 12, 2010 | 06:44 PM
Flash319's Avatar
YFZ, Most 90-95's had the rear abs. The modulator is on the passenger side frame rail and you can see the lines run over to the PS pump.
I am not sure about the V6 stuff. The mounting will be the same but not sure about the inlet outlet position. The bodies are the same between the V6 and 4 but not sure on the piping locations. I new buy 3slow trucks...........
Old Apr 12, 2010 | 11:25 PM
Sweet, so as long as the inlet and outlet on the radiator are in corresponding places with my radiator, then I'm good.
Thanks!
Old Apr 13, 2010 | 07:22 AM
hilandfrog's Avatar
Thanks for the thoughts
I guess I'll take a look and see what fits.....
Round fan,
Fan shroud,
Rad......
I'll take some pics and we'll look at the similarities and differences.
Repo
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
mreagen
Oct 5, 2015 04:27 PM
scott90
Oct 4, 2015 09:21 AM
Matthew Perez
Sep 28, 2015 05:43 PM
