R150 (2wD) Can I couple a transfer case to this transmission?
Old Aug 24, 2023 | 05:23 PM
James Bond's Avatar
I have a 1992 R150 (2wD) transmission. Can I couple a transfer case to this transmission? If so what transfer case or parts will I need ?
​​​thank you
Old Aug 27, 2023 | 07:09 AM
slacker's Avatar
divorce transfer ... or surgery on the 2WD (lots of work and expense)
personally , I think your best to find a 4WD tranny
Old Aug 27, 2023 | 08:39 AM
James Bond's Avatar
Thanks for the reply. ​​ Yes i had assumed (surgery) disassembly and reassembly would be involved. What type of expense are you referring to ?
Still hoping to hear from someone who has experience coupling a transfer case to a 2wd r150 and whether or not this is possible. A​long with the additional parts that would be required.
Thanks again
Old Sep 3, 2023 | 05:33 PM
aztoyman's Avatar
This is a video from another Toyota forum where the guy used the guts of a 2WD R150 to fix his 4WD R150. Maybe you can see why you need a 4WD trans to attach the T-case.
Old Sep 7, 2023 | 03:10 AM
TheresaStephens's Avatar
Thanks for the video sir.
Chris.parshall@kiewi
Dec 30, 2021 05:30 PM
CitrusTheDragon
Jun 17, 2013 12:10 PM
98forunna
Feb 18, 2013 05:47 PM
slosurfer
Aug 20, 2008 05:05 PM
