questions need help with
Old Apr 2, 2015 | 08:03 AM
tham1992's Avatar
When I tore the motor down to rebuild it everything looks fine but there was a piece of aluminum and what looks to be a spring in the oil pan anybody know what this could possibly be from
Old Apr 2, 2015 | 09:18 AM
Terrys87's Avatar
Which motor? Usually I find Timing Guides in the oil pan. Pictures of the spring would help. Since you have the motor tore down, it needs to go to the machine shop to find out if it is rebuildable and what will need done. At this stage of the rebuild process, I would not be to concerned with the spring other then where it came from.
Valve spring or spring on the Chain Tentioner is all I can think of right off.
Old Apr 2, 2015 | 09:36 AM
tham1992's Avatar
Its the 22re. And its at the machine shop just took it to a machine shop this morning and the shop I took it to is a high performance shop that builds race car engines so he should know whether or not its rebuildable
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
