Problems with manual windows
Old Jan 26, 2019 | 09:23 PM
88chuck's Avatar
88 pickup, manual windows... 2 issues... the driver window dosent seem to go all the way up... small gap showing at the top at full window travel. I installed a new regulator in hopes that there was something wrong with the old one..
2nd issue, RS window gets stuck at 1/2 travel. I replaced and ruined a new regulator ( stripped the gears ) . Any ideas or help on either problem would be appreciated.
Old Jan 27, 2019 | 09:17 AM
NYHumpinUtah's Avatar
Welcome
Do you have a FSM? (factory service manual) It has instructions for replacing the windows, you can also look online for youtube videos on the subject
Good luck
Old Jan 27, 2019 | 07:05 PM
muddpigg's Avatar
So i’ve Been plagued by driverside window problems. Have found aftermarket regulators to be about worthless. Gears strip out in a day or 2. I’m also plagued by random window breaking. On 4th piece of glass. Damn glass is getting expensive. Currently running a aftermarket regulator from a pick up trimmed to fit a 4rnr. After doing this was when windows started breaking. So though process of elimination I think the trimmed down regulator is breaking windows. Like I said aftermarkets are crap so far. Tried VSO and ACI. So I shut door extra softly at the moment.
Old Jan 27, 2019 | 07:16 PM
old87yota's Avatar
You will want to make sure the rubber window track is clean and not pinching the window. Applying a little silicone paste (dielectric grease) to the rubber helps lubricate the contact surface between the rubber and glass.
Make sure that metal is not directly contacting the glass.
Old Jan 27, 2019 | 07:27 PM
muddpigg
What's your ride? Are there no salvage yards in watertown?
Old Jan 28, 2019 | 06:50 PM
muddpigg's Avatar
Originally Posted by NYHumpinUtah
muddpigg
‘86 4rnr. Old yotas didn’t fair well with the road salt. Better update my location. Moved to LA this summer. By LA I mean lower Alabama😜
Old Jan 28, 2019 | 09:24 PM
Originally Posted by muddpigg
‘86 4rnr. Old yotas didn’t fair well with the road salt. Better update my location. Moved to LA this summer. By LA I mean lower Alabama��
There's a 86 pickup at my salvage yard, I think it still has the complete doors on it, I believe the pickup & 4runner are the same. What part do you actually need for the window(s) is it left, right or both.
Old Jan 29, 2019 | 04:07 AM
muddpigg's Avatar
just control arm for manual driverside vent-style door glass. Like I said above tried 2 different aftermarket control arms and they were crap.
Old Jan 29, 2019 | 07:40 AM
Opps
These don't have vent windows
Sorry
Old Jan 30, 2019 | 10:01 AM
75w90mantraN's Avatar
Yes^^
That or worse, window tracks got bent somehow (prior theft attempts, door damage).
At least you dont have to deal with power window issues like switches and motors.
The salvage yard can definitely be an interesting solution. 'Custom-painted' doors touch.
Old Jan 30, 2019 | 03:13 PM
muddpigg's Avatar
Opps
Sorry
Thanks for looking out!! Heard of a localish yard that is labeled as closed that I’m told a big yota section. Fingers crossed.
gmahan2
Jan 15, 2013 08:03 AM
