Power Steering Conversion-93 truck 4cyl
Please help me. my muscles aren't big enough to turn the wheel. i recently acquire a 93 reg. cab 4 cyl truck with 33 tires and i want to convert it to power steering. i have never worked on a toyota before and clueseless on what i need to do this mod. please help a new guy here. sorry, i did try search and not really sure though. i live in washington state and so if theres anyone here from there, i would really appreciate if you can show me what you did. thank you in advance.
You'll need:
Power steering pump and both brackets for it- one bolts to head and other bolts between the engine block and alternator.
Idler pulley assembly (adjusts the drive belt) if it's not on the pump bracket
drive belt
pressure hose from pump to steering box
steering box
hose from steering box to fluid cooler
fluid cooler (it's a simple loop of pipe that mounts in front of radiator)
return hose from cooler to reservoir
reservoir
supply hose from reservoir to steering pump
drive belt
steering box
reservoir
i just picked up a box,pump(with reservoir on top) brackets and hoses from a 91 4runner 6cyl and i don't think it will work. i think the box will but i don't know about the pump and brackets. also the runner doesn't have a cooler...only the box on the pass-side where it connects to abs lines and stuff. wierd.. any comments?
voiddweller
19
May 2, 2016 09:10 PM
Bamripzit
Jul 19, 2015 01:17 PM
