pop that axle pop...pop that axle
so my axle and/or frontal components are making a popping sound when i turn the wheel in either direction. it will make one pop if and when i turn the wheel in one direction,and then the same sound the other direction. (it makes the sound at about a quarter turn not full lock.) and if i rock the sterring back and forth it will make pop,pop,pop,pop, sounds.
i have done a solid axle within the last 1500 mile and the sound didnt begin until about 500 miles ago. i have tried tightening the u bolts, hanger and shackle bolts high steer arms lower trunion caps, castle nuts on all steering components, and shock mount bolts.
the only thing i can think of, is it is in the knuckle region maybe the spindle nuts broke in or work loose a little and now the pre load is off. suggestions?
i may be over complicating the sound but deatails help. thanks all.
tried that... tthe only thing i noticed was the steering stabalizer bushing moved with the sound. like a jolt almost. but i removed it and it does the same. now that i think of it the sound happens when i hit bumps too., which is why i tightened up the suspension
polo451
13
Nov 20, 2016 07:49 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Snowheeler
Aug 21, 2015 04:34 PM
