Polishing my intake - ocd can help sometimes lol
Old Jun 5, 2009 | 04:04 AM
SwampThing's Avatar
Originally Posted by iamsuperbleeder
lmao, you first
then do your entire frame!
We both know the only thing I'm OCD on is destroying my trucks.
*Driving slowly down the beach* "Oh look, it's something different!" *Rollover*
I've only once washed the ST2 since I've had it.
Old Jun 5, 2009 | 06:42 AM
flashkl's Avatar
shiny shiny. I say dress it up with some rhinestones and a bedazzler.
Old Jun 5, 2009 | 07:18 AM
aviator's Avatar
LOL you gotta know some rapper some where is going to get the idea to do up his intake with diamonds/rhinestones/cubic zirconias to add some bling to his ride...
Old Jun 5, 2009 | 08:44 AM
Jay351's Avatar
so damn funny!
Old Jun 5, 2009 | 09:03 AM
  #25
mrddk92's Avatar
I was thinking it might be fun to just do the whole truck haha. Who needs paint when you can have polished sheetmetal?
Old Jun 5, 2009 | 03:12 PM
  #26
iamsuperbleeder's Avatar
as long as that would take, it might look cool!
lol
finish it off with 2000 grit, and just spray it with clean coat, and BAM!
Old Jun 5, 2009 | 03:33 PM
  #27
mrddk92's Avatar
Haha lol. Has anyone seen the toyota a-bat? Its a hybrid concept truck but it loooks all metallic.
Old Jun 5, 2009 | 03:45 PM
  #28
flashkl's Avatar
Old Jun 5, 2009 | 04:17 PM
  #29
Boyd Coddington's Alumitub
Old Jun 5, 2009 | 04:32 PM
  #30
mrddk92's Avatar
haha those are cool i wonder how the a-bat would do offroad i wish they would just bring back the gen3 trucks and give em more power and economy that would be awweessome but i gues the majority like the big bubble trucks haha
Old Jun 5, 2009 | 06:01 PM
  #31
ovrrdrive's Avatar
I'm guilty too... And as TN said, it gets all crappy looking after about a month. I'd try to strip all the grease off of it with some acetone and spray clear on it if I were you. Once the engine is put together you won't be able to do it.
Old Jun 5, 2009 | 06:17 PM
  #32
well hell, before paint, both my upper and lower manifold's looked quite similar; but of course I only have a pre-paint pic of my lower manifold
you wanna talk about something that's a PITA to clean...
granted it's not polished, but it still takes a long time...
and they turned out like so:
Old Jun 5, 2009 | 07:02 PM
  #33
mrddk92's Avatar
haha yeah i can still see the casting surface dimples and stuff, mine is a lil smoother lol so it shouldnt collect so much dirt and stuff i hope. i almost just sanded the letters completely off because it was a pita to sand and polish all around them, i did take off the double ridge part though......right where the flat part in the middle meets the part where the letters are
Old Jun 5, 2009 | 07:05 PM
  #34
mrddk92's Avatar
i still neeed the inside cleaned, i think ima take it to a machine shop for that but idk i got most of the larger deposits out so idk how much the rest will effect the performance. there was like 1/3 of an inch of buildup where the egr comes in
Old Jun 5, 2009 | 07:28 PM
  #35
desertcamper67's Avatar
What about the build up on the inside? Can that be cleaned up a bit on the truck or will debris falling down into the lower part and eventually into the cumbustion chamber do any damage? I just took off my throttle body to clean it up and address the TPS.
I couldn't believe what I found behind it. Its like thick, moist brownie residue stuck to the pan. Comes off with the finger but I want to spray some throttle body cleaner in there and see metal again. Is this a good idea?
Old Jun 5, 2009 | 10:30 PM
  #36
mrddk92's Avatar
Idk I would take it off to clean it. But some tb cleaner can't hurt really, I would use that but don't go. Scrapin away, there's a lot o stuff in there. But even with it off its near impossible to get all that out. Its all just exhaust deposits. Uuugggh.
Old Jun 5, 2009 | 11:10 PM
  #37
mikelusk1's Avatar
delorean came in stainless steel from the factory
and this is just plain shiney
Old Jun 6, 2009 | 08:30 AM
  #38
Okay I will take it off today. I just looks so bad I want it gone.
Old Jun 6, 2009 | 09:57 AM
  #39
vital22re's Avatar
totally a bro
while you've got the manifolds off, you should gasket match everything. may help with the cams
Old Jun 6, 2009 | 10:31 AM
  #40
mrddk92's Avatar
was that to mee? i wanted to get my heads ported and get o/s valves but i couldnt justify 850$ for like 10 hp maybe. it just aint worth it, ima be fine withe headers and cams i think. eventuall im get a 3.4 so i just want my 3.0 to last untill i can do that...i might do some gasket matching though. would just use a dremel with an aluminum oxide grinder ? or i could prob use a drill
