PO switched to synth....crap or ?
Old Feb 24, 2008 | 02:09 PM
babyfood1217's Avatar
The truck that I will be purchasing has been switched from trad. oil to synthetic, and while I have heard some bad things about synthetic, they don't seem too big. From what I understand (from this forum, my former jeep forum, and personal research), synthetic oils "can", and I repeat "can" lead to oil leaks. This appears to be primarily because the detergents in the synth. oil essentially clean out any of the gunk in the seals that help to keep the oil in. The oil leaks that seem to develop are not very large, but they are noticeable. Since the brand new 22re that is in the truck was started out with synth. when it was installed (18k ago), I am not too worried about this.
I didn't not let this oil-switch affect my buying decision, but I am curious if are there any tips (that I havene't read yet) for a person running synth. on a 22re? I figure, regular oil level checks and changes are to be assumed, so anything else?
Thanks in advance, and when I finally get this thing, I'll post pics
Old Feb 24, 2008 | 05:22 PM
Georgiadave's Avatar
There is no reason why the engine should leak because of synthetic oil. The additive package is not that much different from dino oil. The oil is the same viscosity at temperature either way.
Penzoil Platinium Plus 10-30 at Walmart, or Castrol 0-30 made in Germany (look at the back of the bottle for where it is made) would be my recommendations.
Old Feb 24, 2008 | 06:32 PM
mr toytech's Avatar
i run mobile one synthetic 10-30 in my 3.0. no problems.
MMA_Alex's Avatar
penzoil? *shudder*
friends don't let friends run penzoil.
mobil 1 is the best stuff off the shelf. amsoil is better, but typically needs to be custom ordered.
if you want to extended change intervals i'd recommend doing more frequent filter changes.
do a search, theres a ton of oil threads on here full of bad info about the voodoo magic of synthetic oil
oh, and be prepared for a ton of stupid responses to this thread...k, you guys can post 'em now
Old Feb 24, 2008 | 06:37 PM
Targetnut's Avatar
I'm running Castrol Syntec in my truck.
I recently replaced the head (perfomance upgrade) and I did not have any leaks at 230,000 miles
I think synthetic provides an extra measure of durability that will make the engine last longer, but if you run conventional oil and chage it when you are supposed to you should not have any problems.
Old Feb 24, 2008 | 08:27 PM
Jay351's Avatar
Originally Posted by MMA_Alex
penzoil? *shudder*
Thats all I run (10w30 dino)
The synthetic oil change over will only cause problems in higher milage engines. You have nothing to worry about.
I would keep changing it every 3000miles or so. I don't trust old after that long
Old Feb 24, 2008 | 08:45 PM
infiltrator's Avatar
yes, there are leaks when you switch to synthetic over dino. read the threads on it.
sure dino juice and synthetic are the same, but synthetic will clean up the seals, thus causing the gunk that was there holding on to be lost.
just... read some threads...
Old Feb 24, 2008 | 08:48 PM
TOYOTA 1's Avatar
ill take a oil leek over a spun rod bearing, lol
Old Feb 24, 2008 | 08:52 PM
dbcx's Avatar
You do order Amsoil but it is not "cutom ordered" you just get what you need.
Here is a good article if i can get it to work
http://www.ferrarichat.com/forum/faq...=haas_articles
that will answer all your question and explains alot, and prove alot of folks on here know nothing about oil they think they do
Old Feb 24, 2008 | 08:54 PM
Matt16's Avatar
I switch from black, dirty dino oil (in truck when bought) to Mobile 1 higher milage 10W30 synthetic. I haven't leaked a drop. There is NO oil on the any of the edges of the gaskets (oil pan, rocker cover, timing cover, front seal or rear seal. I think my engine is fairly tight, but it still has 270 000km (170 000mi).
Old Feb 24, 2008 | 08:55 PM
Matt16's Avatar
I'd be curious to know how many people, from their own experience, have leaked after the switch.
Old Feb 24, 2008 | 09:05 PM
dbcx's Avatar
I run and sell Amsoil,and just bought a 1997 4runner (new to me) with 197k miles. I swapped over to Amsoil , ive had no leaks any where. I cleaned a few dirty spots when i got it ...their still clean.
Old Feb 24, 2008 | 09:35 PM
TOYOTA 1's Avatar
wow thats a long read about oil, but it makes sense!
Old Feb 24, 2008 | 09:40 PM
dbcx's Avatar
Yeah i forgot to mention it was a little long. But its worth the eye opening
Old Feb 24, 2008 | 09:43 PM
TOYOTA 1's Avatar
ya think im gonna run thinner oil, but always synthetic 4 me
Old Feb 25, 2008 | 04:13 AM
MMA_Alex's Avatar
I meant that you had to order it, unless you're lucky enough to have a store nearby that sells it
kawazx636
Oct 6, 2021 03:03 PM
beltcutter
Sep 30, 2015 06:14 AM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
