please help me finding parts for my 94 22re pickup
Old Aug 1, 2018 | 02:15 AM
lnn11583's Avatar
hello all, my project is to put ac into my truck. it’s the base model without factory ac. im going to need all the help finding parts to complete this project. if u know anyone parting out their truck. let me know, thanks
Old Aug 1, 2018 | 08:49 AM
dropzone's Avatar
Fossilized
https://www.yotatech.com/forums/f120...rs-etc-221645/
Old Aug 1, 2018 | 08:58 AM
jakey poo's Avatar
You're on the right track with wanting to find someone parting out an AC rig. I would think your local classified would be the best place to find one
Old Aug 1, 2018 | 10:36 AM
wyoming9's Avatar
Red face
Do yourself a Big favor get everything from one vehicle .
Better Yet have the complete vehicle
If at all possible get a recent rear end where the AC worked and can be tested and run before the wallet comes out .
My luck on used parts is the worst I would be using all new parts
Maybe look at the after market kits might be cheaper in the long run
Old Aug 2, 2018 | 04:59 AM
lnn11583's Avatar
thank you all
i will post pictures when this A/C project is completed.
Old Aug 2, 2018 | 05:01 AM
lnn11583's Avatar
22re ac
i did, but none got it, probly scrapted.
Old Aug 2, 2018 | 07:06 AM
Discombobulated's Avatar
You can also call yotajims here in CO, they should have everything you need but not sure on price and shipping but worth a call.
Old Aug 2, 2018 | 07:17 AM
lnn11583's Avatar
discombobulated
appreciate it.
Old Aug 2, 2018 | 07:21 AM
lnn11583's Avatar
wyomiy
thanks for good advice, i probly buy the compressor, condensor,expansion, low pressure line and high pressure line new. im more concern finding the right compressor bracket, idle up diagpram and idle up cvc valve. also the a/c controller.
Old Aug 4, 2018 | 04:30 AM
dyna105's Avatar
Not sure if Toyota still offers it. I bought a complete factory kit for my 1993 back in late 1994 for around $600-$700 if I remember correctly. Came with all the parts, plus directions.
Old Aug 4, 2018 | 07:04 AM
lnn11583's Avatar
i kind of doubt it. it’s so long ago, if they still offer it probly cost more than what i got the truck for, ill just keep on digging, atlest it’ll be fall and winter soon
Old Aug 4, 2018 | 02:45 PM
FYI I went through multiple compressors from the yard that the clutch was shot, clutch kits are not available nor is the kit from Toyota, best bet is to source everything but the compressor and look for a reman Denso compressor
Old Aug 5, 2018 | 04:16 AM
lnn11583's Avatar
22re a/c
yea i was going to buy new compressor and dryer and oil.
Old Aug 5, 2018 | 04:18 AM
lnn11583's Avatar
did you install the whole a/c system to your truck yourself or had some one do it?
Old Aug 5, 2018 | 07:46 AM
A good friend that was a yota mechanic at a dealer opened up his own shop and he did most of the install as he used to install the full kit at the dealer.
I went to the yard as it’s local and got all the parts for him and he did the rest with the exception of popping the little square out on the ac controls and putting in the switch, I had already done that cause I was excited
Total was 600 bucks BUT after going through 3 compressors if I remember right I finally decided to get a reman which was 200 at the time. So all in all after having to recharge the system and swap the compressors a bunch it ended up being 900 bucks..but it was worth every penny
Old Aug 5, 2018 | 08:28 AM
lnn11583's Avatar
22re a/c
do you still have the truck? if so could you take some pictures showing how the vacum connection on the idle diagram(locate on the intake) and the vsv valve(locate on the valve cover). the rest should be plug and play. i saw all the extra connections on my truck that are designated for the A/C system.
Old Aug 5, 2018 | 09:38 AM
Yea I can take some pics, todays a bit busy but I can get some up by tomorrow.
Old Aug 5, 2018 | 12:48 PM
lnn11583's Avatar
22re ac
no rush, anytime you’re free to do so. thanks
Old Aug 6, 2018 | 10:41 PM
papawhellie's Avatar
I have a 94 2wd runner with AC parting out. Don’t have a lot of time to pull stuff, 56 and in nursing school. Might could get someone to pull for beer money. It’s 3.0. Ac did not work but I never charged it. Head gasket blew within 3 months when I was flushing rad and tranny. Text me if interested seven o 6 seven 401086. I start clinical 8/20 balls to wall.
Old Aug 7, 2018 | 07:22 AM
lnn11583's Avatar
22re
thats too bad, my truck is a 4 cylinders so i can’t use any of the v6 stuff, otherwise i would have bought if from u.
