Please help!!
Whoa! Slow down!
You need to give us a little more information.
Did this just start to happen?
Under what conditions is the truck overheating? (like stop and go traffic, highway driving, driving up a long hill, temperature outside etc.)
Was the thermostat installed correctly so it is not put in backwards?
Is the fan, fan clutch and fan shroud in place, and in good condition? How about the radiator cap?
Assuming that the parts you replaced were quality and not faulty you could have a bad fan clutch, or a clog in the engine somewhere.
The more information you give us, the better we can help you.
Whoa! Slow down!
Yes had a mechanic do the work for me cause k was to busy at work to have time to do it. Well about 3 weeks ago I was coming to work one day got about half way to work and it just quit blowing heat teml gauge was still near the cold mark then the closer I got to work the further up the temp gauge would go and every time you drive til it overheats I have to add about a quart of water so that's when I replaced the parts with new ones cause the water pump was wining and I have no clue still.overheating after all them parts have been replaced and no water in the oil
FS[PacSouthWest]: 1991 Toyota Pickup 4x4 Ext Cab $4000 in San Diego, CA
xtremewlr
Nov 6, 2015 11:26 AM
deerleasetruck
Nov 2, 2015 03:13 PM
☆OMI☆
Oct 31, 2015 10:54 PM
FS[WestCanada]: 1988 Sas'd toyota pickup
RoadRage
Oct 9, 2015 07:43 PM
