PCV Hose Location for 3.0L '95 4Runner?
Old Oct 27, 2007 | 04:24 PM
Nuckaman's Avatar
I wanna add some seafoam to my 95' 4Runner, can someone point out the PCV hose where I'm suppose to pour the seafoam in?
Thanks.
P.S. It's for a 3.0L engine.
Old Oct 27, 2007 | 04:37 PM
keithguts's Avatar
You can also do it using your brake boster line.
Old Oct 27, 2007 | 06:03 PM
OSU4Runner's Avatar
Old Oct 27, 2007 | 06:54 PM
n4ynu1010's Avatar
Seafoam
I used a 3/8"male barbed X 1/8" male barbed adapter and a small length of 1/8" tubing (that way not so hard to keep running with PCV disconnected) and sucked it out of the can (whole can) throttling it while it was sucking it in then followed the rest of the directions , it did a beutiful job on the throttle body and throttle plate but that was as far as I could really see , I am sure it cleaned the rest as good
That in my gas and my intake has helped mine purr a bit better
It would probably not be a good to pour it in as that possibly could cause a problem if you actually got liquid to the combustion chamber .....................would not be pretty
shisha1999
Mar 16, 2016 12:25 PM
coryc85
Sep 9, 2015 06:24 AM
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
coryc85
Jul 7, 2015 04:05 AM
