parking brake question
Old Nov 29, 2010 | 09:06 PM
boffy95's Avatar
From: I live part time in southern VT and part time in western mass
teuf does that actually lock up the drum brakes or just the drive shaft?
Old Nov 29, 2010 | 09:21 PM
Teuf's Avatar
Just the drive shaft.
Old Nov 30, 2010 | 05:47 PM
Teuf's Avatar
OK, as far as I know thats not even looked at in Ca. Its just a smog test and thats it.
Old Dec 1, 2010 | 02:52 AM
Cyberman's Avatar
Too bad there isn't one for the V6.
Old Dec 1, 2010 | 03:30 AM
  #25
xxxtreme22r's Avatar
Originally Posted by razed
i dont want to give bad advice just like everyone else doesnt want to do either but a trans brake is not DOT legal for park or e-brake and would fail a vehicle that has to be those inspections.
it won't fail in PA. Pretty sure in Teuf's thread on the e-brake I had posted up the PA code on the e-brake system. This isn't to say other states are not different though.
The bell cranks do seize up and is probably the most common problem on automatic trans e-brake problems. I would say less likely on a manual trans though unless your one that likes to park it in gear.
Razed must have not ever had to deal with these sticking to say it's the pawl under the dash.
Ask 92 TOY on how his e-brake handle felt with the cranks seized up. Pretty sure he will tell you he had the full range of motion on his handle and it felt "normal".
Old Dec 9, 2010 | 06:24 AM
  #26
boffy95's Avatar
It seems like it would put a lot of stress on the rear-end if you ever used it when you were moving. Also if it just locked up the drive shaft the two wheels could just spin in opposite directions (provided it was an open differential), that would probably make you go out of control.
Old Dec 9, 2010 | 11:22 AM
  #27
angrybob's Avatar
Before you tear into anything make sure all the parts in the PKB system that are supposed to move in fact do so, then check the cage clearance. Should be a 0.6mm shoe to drum clearance.
FSM says the following:
"CHECK OPERATION OF AUTOMATIC ADJUSTING
MECHANISM
(a) Move the parking brake lever of the front shoe back
and forth, as shown. Check that the adjuster turns.
If the adjuster does not turn, check for incorrect
installation of the rear brakes.
(b) Adjust the adjuster length to the shortest possible
amount.
(c) Install the brake drum.
(d) Pull the parking brake lever all the way up until a
clicking sound can no longer be heard.
CHECK CLEARANCE BETWEEN BRAKE SHOES AND
DRUM
(a) Remove the brake drum.
(b) Measure the brake drum inside diameter and diameter
of the brake shoes. Check that the difference between
the diameters is the correct shoe clearance.
Shoe clearance: 0.6 mm (0.024 in.)
If incorrect, check the parking brake system."
Charecter1
Nov 6, 2023 10:08 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
terminator
Jul 27, 2015 07:13 PM
CanRunner
Jul 20, 2015 01:29 PM
87turboPA
Jul 9, 2015 05:58 AM
