From: exo-reality -wave if you see me; Front Range, CO
panhard bar bracket
Howdy. 1995 4runner
In the process of leveling my rear panhard bar. (Put new springs on and bar is like 4" out of level). Probably going to get one of Roger Browns' drop brackets.
But in the process of measuring I noticed my bracket looks wonky. And for a supposedly factory pressed-steel part, it sure looks odd.
Check those non-circular holes on the sides. And if you look closely the triangular shaped opening is quite bent up.
In July I replaced the lower strut arm. Was quite bent. Yet fuel tank and its protector plate were not. HIDK.
Does this look really weird to anyone else? I don't think I'm going to worry about it whatever. It just holds the panhard bar in place. (See 4crawler website for great info).
