P0336 code help
Old Aug 1, 2016 | 05:23 PM
pauldbmx's Avatar
P0336 code help
I'm having this code come on and not sure how long its been on. The CEL has been on since I've owned it.
Symptoms are:
- shuts off only after initial start up (runs for about 10 seconds then dies but if you drive a short distance it wont die)
- when cruising it feels like its missing but accelerates fine.
Parts fixed/replaced:
- replaced the crank position sensor
- replaced the igniter
- fixed a short in the ecu
- replaced the distributor
- new plugs
Any ideas on what could be causing this?
Old Aug 1, 2016 | 07:33 PM
fierohink's Avatar
A worn drift key for your crank pulley allowing it to wander?
Old Aug 2, 2016 | 02:58 PM
pauldbmx's Avatar
That was replaced when I rebuilt the engine 10k ago. Actually what ended up killing the last engine. The crank broke at the key and didn't have any oil pressure, overheated, and no charge from the alternator. Bad day
Vernsyota
Mar 5, 2016 04:59 PM
128keaton
Mar 1, 2016 06:50 PM
your-real-dad
Engine Swaps
Feb 24, 2016 10:44 AM
FinallyOffRoad
Feb 17, 2016 08:39 AM
astein34
Aug 28, 2002 07:31 AM
