Oversized Spare Tire & LSP Brake Valve
Old Mar 15, 2013 | 10:32 AM
corich's Avatar
I finally got a proper spare tire to match the 32" trail tires on my '87 4Runner. It'll squeeze into the stock spare location under the bed, but it's a tight fit. (Perhaps because there's a receiver hitch eating up a couple inches of the space in there.)
What's bothering me is that the tire is in contact with the load sensing proportioning valve arm thang. I'm sure it's pushing it to the side a bit, but I'm not sure how much.
Since I don't really understand how the LSPV works, I'm not sure if this is a safe situation. I'm headed to Moab shortly (tomorrow!) and I'd rather not drive I-70 through the mountains with brakes that aren't doing what they are supposed to.
Can anyone advise me on whether this is okay? I'm sure I'm not the first one to have this issue.
I'd really rather not give up the cargo space, but if I have to, I'll make it work with the tire on the roof or in the bed. Thanks a ton, in advance.
Old Mar 15, 2013 | 11:00 AM
arlindsay1992's Avatar
Some people have been known to bend the rod out of the way. Do you think you can safely bend it to create enough clearance without changing the adjustment?
Old Mar 15, 2013 | 11:40 AM
niall's Avatar
As the arm is Moved up at the axle end, (suspension compressed due to weight in the rear) It opens the valve, allowing the full amount of fluid through, thus increasing rear braking performance.
It is safe to cut the arm, and ziptie/clamp the remaining portion in the UP position. All it will do is increase the rear brake bias (but not to a rear lockup situation)
Old Mar 15, 2013 | 01:06 PM
85TurboRunner's Avatar
I wouldn't worry about it. Since you have larger tires anyway it might be a good idea to make a spacer to lift the rod up giving a little more power to the rear.
On my old 4runner I just cut it and zip tied it up like mentioned above. My current truck came from the factory without an LSPV all together.
Old Mar 15, 2013 | 01:17 PM
corich's Avatar
Thanks, guys, especially to niall for the explanation of how the LSPV works. I might try to "reshape" it as arlindsay suggests, but it sounds like it's not a huge issue.
Old Mar 15, 2013 | 01:39 PM
mt_goat's Avatar
Mine is cut off and wired up all the way. Works fine for me.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
