Overheating issue
#61
Yer all nutz. 91toyota, you've got a blown head gasket. I had all of the same issues including the crazy idle surging. At 1st, mine would only surge when I'd touch the brakes with the a/c on,...then it started doing it as soon as it'd warm up without the brakes being touched. It would get hot as hell too when it surged at idle, so I replaced the whole cooling system. Needless to say, it would still get hot. This is when I noticed it was the head gasket. The 3 rear cylinders had coolant in em. And for deserthound,.... How could you not notice your timing chain grinding thru your guides into your cover?!?! It makes a horrible rattling sound as if you've got 100 BB's bouncing around in your engine. You should've noticed this since you say you hear any weird noise that's coming from your purring kitten.
#63
91 yota, I feel for you too. I'm pretty sure I gotta vacuum leak on top of my blown gasket. I'm about a week from havin her all buttoned up. I'm probably gonna go but a -load of new hose and replace all the vacuum lines to be safe. I know it'll run better than before, but I'm eager to see if it still surges when the a/c is on.
#64
yeah...I just can't find out where the leak is coming from. Maybe I should buy some starting fluid and replace the lines that I can see that are cracked and has a hole in it. I'll have to get a can of starting fluid and have at it...lol
#66
That's a great idea! Where do you find a box of plugs? Like at any auto parts store? Can I just use duct tape over the ends or is that a bad idea because I guess it could get sucked in right?
Also, can missing bolts cause a vacuum leak? Like that plate on the back of the head. I don't think I have all the bolts in...could that be the vacuum problem? Thanks!
#67
Yeah, a couple bucks will buy a box of assorted sizes at most auto parts stores. Duct tape would probably work too. I'm not very familiar with the 22re.
#71
The dashpot is there to slow down the throttle/butterfly when it is closing so you don't run a rich mixture and cause backfiring (technically 'afterfiring', but they sound a lot alike). The piston on the dashpot will most likely touch the tab on the throttle when the throttle is 'closed' but if it is set incorrectly it could cause the throttle to not close completely. This will cause the TPS to not register 'idle' to the computer and will confuse the ECU and could affect ignition timing, idle speed and quality.
If you're still having troubles with getting the idle to stabilize, you need to check the throttle position sensor: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml. There is information about setting the throttle plate, dashpot and a lot more there.
Also, make sure you've got clean spark plugs with the correct gap setting.
Are you getting the check engine light lighting up?
#72
Long thread, and I did not read them all but..
1) Does your thermostat have a small hole in it for air bypass? If not, go get one. Install with little hole to the top.
2) We all assume you installed it in the correct direction, spring inside engine?
That little hole, may have a "jiggle gizmo in it" will purge all the air.
That's all...
That's all...
#73
That's all...
That's all...
#74
#75
i just got a new rad and i've had to burp it twice in like 300 km. ...its lame, so i may have a similar problem, but i don't over heat, one time while idling in traffic it started to over heat but then i burped and it hasn't come back yet...i still sometimes hear the water moving inside, meaning air in the system.
#77
I have that ezact problem with my 94'. I can't get the air purged from the coolant lines. I've tried everything. The closest I've come to fixing the problem was drilling 2 - 1/8" holes in the bottom flange of my therm. It helped, and in fact worked for the most part, but I wasn't sure that it was opening correctly so I went back to running without a stat. My idle has been regularly above normal but not more than 1100 or so.
If you find out anything more about it, please post an update.
#80
Hmm...thats interesting. Did you put stop leak in or anything like that? Is it "actually" over-heating? Could be a case of a faulty sending unit. My dads ford had a faulty sending unit on his 460 and it said that it was over heating. Never actually was. New sending unit was a couple bucks and fixed the annoying problem.
Also, how is your fan clutch? I'm guessing if it gets hot like that on hot days...something must be wrong.
