overheating 3.0
Old Apr 30, 2007 | 06:58 PM
tarpon40's Avatar
overheating 3.0
Replaced headgaskets on 3vze, not have an overheating problem.
It seems like there is no water circulation. Tried with two different thermostats (new and old one). When you start the truck, the water temp just keeps rising till it boils over. Any ideas why this would be happening?
Old Apr 30, 2007 | 07:01 PM
DeathCougar's Avatar
airbubbles likely trapped.
Take the thermostat out to see if air is the problem. If it runs cool, then you know where the problem is.
Old Apr 30, 2007 | 07:03 PM
breknraj's Avatar
Sounds like you still have air in the system, did you bleed the cooling system with the front end of the rig higher, and the heater control full on?
Old Apr 30, 2007 | 07:40 PM
TNRabbit's Avatar
If that doesn't work, did you put your head gaskets on backward & block coolant flow?
LotOMiles
Sep 14, 2015 11:45 PM
sanctfy
Sep 13, 2015 06:33 PM
noahstancik
Sep 10, 2015 10:47 AM
FJtoyman
Sep 8, 2015 04:47 AM
seab1209
Sep 3, 2015 05:41 PM
