ok heres a stupid question how do you take off the shifter on a 5 speed
Old May 6, 2009 | 09:15 PM
gary96360's Avatar
i just did a body lift and want to bend the shifter forward but i cant seem to remove the shifter
Old May 6, 2009 | 10:10 PM
Matt16's Avatar
Push down and turn IIRC. Obviously, you have to unbolt the boot from the floor.
Old May 6, 2009 | 10:11 PM
toyNG's Avatar
Not sure where you're getting hung up, so I'll start from the beginning.
-First, you need to get access to the shifter. So remove any parts of the center console that are in the way. You'll also need to unscrew the shift knob.
-There should be a plate that attaches the the rubber boot, remove it.
-Slide the boot off.
-Remove the snap ring that is holding the shift lever in. It should just slide out now. A pair of snap ring pliers make it easy, but I've done it without them.
Old May 6, 2009 | 10:16 PM
gary96360's Avatar
ive been driving with no shifter boot for a couple of days now but i dont think there is a snap ring
Old May 6, 2009 | 10:19 PM
stormin94's Avatar
I just have to hold mine in 2nd after my body lift. Otherwise, no issues. Let us know how this ends up.
Old May 6, 2009 | 10:21 PM
toyNG's Avatar
Have you tried removing the shifter plate/base? I think there are just 4 bolts holding it in.
Old May 6, 2009 | 10:27 PM
dropzone's Avatar
Fossilized
there should be a shift collar retainer, unless yours in rusted in there like mine,
you should be able to push down on the retainer, as you are pushing it down, turn it counter clockwise approximately 1/8 of a turn. than it should pop off the two pins
snap ring is found on a Top shift transfer case lever
Old May 7, 2009 | 09:31 PM
gary96360's Avatar
ok i took it off and used a torch to heat it up and bend it forward. i think i bent it too much cuz i have to reach forward for 1st and 3 gear but w/e everything works perfectly yay
Old May 7, 2009 | 10:05 PM
xzyragon's Avatar
ive never been able to remove my shifter knob... damn thing just wont unscrew
Old May 8, 2009 | 09:21 PM
gary96360's Avatar
use two pliers, one to hold the shifter and the other on the knob and thats it
Old May 11, 2011 | 05:51 PM
ra33it's Avatar
i know this is an old thread, but thank you everyone. I put in my new marlin t-case and shifter bushings, and I couldn't figure out how to get the shifter out.... T case was easy, snap ring... Anyway, THANKS!
Old May 12, 2011 | 06:54 AM
Rod.s's Avatar
I have a problem with my shifter hitting my 4 wheel select shifter when I am in 4-wheel high. How do I get the 4 wheel select shifter out so that I can bend it some, is it the same proceedure?
mdev126
Oct 4, 2015 04:48 AM
coffey50
Jul 28, 2015 10:55 AM
sabine
Jul 18, 2015 03:59 PM
kyletbert
Jul 17, 2015 11:39 AM
wilbertd
Jul 6, 2015 07:39 AM
