Oil pan to timing cover question.
Old Jan 18, 2016 | 04:59 PM
d-wood's Avatar
Is there suppose to be somewhat of a gap between these two? It's like this on both sides. If you look on the corner you can see where the timing cover is actually not flush with the engine block.
Old Jan 18, 2016 | 07:25 PM
highonpottery's Avatar
Your pan looks warped to me. IIRC when I did this my engnbldr tcover was fairly flush to the block, not perfect but better than yours. You're going to be using FIPG/RTV silicone gasket anyways, so goober it up and it should seal the irregularities - that's why we use it. I don't see why it wouldn't seal as long as you fill the gap and have done good prep beforehand.
Old Jan 19, 2016 | 12:05 AM
wyoming9's Avatar
Red face
Do you have the bolts installed that would pull the pan up ??
If you pried things the pan may be bent slightly
Old Jan 19, 2016 | 04:44 AM
d-wood's Avatar
I took all the bolts out and put them back in there respective spots unless the po had something wrong. I don't know.
Old Jan 19, 2016 | 04:45 AM
d-wood's Avatar
Also. I didn't do any hardcore prying. I used a soft wood wedge gently. Guess I'll take it back off and tap it straight. Sucks.
Old Jan 21, 2016 | 05:44 AM
d-wood's Avatar
Are there different bolt sizes in the front that pull it up or something? I didn't notice any different sizes.
Old Jan 21, 2016 | 06:11 AM
Terrys87's Avatar
All the bolts are the same. Your pan does look bent to me. I would suggest pulling it off and laying it on a solid surface and with a block of wood and hammer try tapping it to get it straight again. I have a tough time with leaks with a perfect pan. I feel your pain on having to pull it back off again. Been there a few times myself.
4by4yoter
Jan 30, 2016 09:50 PM
KYLEFOO
Jan 25, 2016 12:36 PM
The Tick
Jan 18, 2016 07:18 PM
Reluctanse
Jan 15, 2016 06:04 PM
Redrezzer
Jan 12, 2016 09:21 AM
