Oil Leak near the Oil filter
Old Sep 25, 2006 | 09:57 PM
Myron's Avatar
Hi, Just wondering if any one came across this issue. When the truck is running, oill leakes from around the oil filter area.....
I just got this truck and dont kwno when it had an oil change. It was sitting for 3 months before i got it..
Any help will be lovely.
thanks
I have a 88 4x4 EFI 2.4l
Old Sep 26, 2006 | 01:02 AM
ovrrdrive's Avatar
Start with an oil change and a new filter to make sure you have enough oil in it and a good filter. Seeing as how its new to you, you'd be better off knowing it had fresh oil in it anyway.
That would also rule out a bad oil filter seal too.
Old Sep 26, 2006 | 03:06 AM
tampabayota's Avatar
my suggustion to you would be to take pixs and give more info
Old Sep 26, 2006 | 04:06 AM
ovrrdrive's Avatar
pics of a leaking oil filter?
Old Sep 26, 2006 | 04:10 AM
Yoda's Avatar
Sometimes the oil pressure sender may leak. It is right next to the filter (behind it)
Old Sep 26, 2006 | 04:57 AM
MMA_Alex's Avatar
definately do the oil/filter change, and make sure there aren't any old seals stuck in there.
Old Sep 26, 2006 | 06:24 AM
AH64ID's Avatar
that was my first thought...
change the oil/filter... clean it all up and see where/if the problem continues. It could be that the gasket cracked after sitting for 3 months...
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
jakebarrett
Jul 10, 2015 07:15 PM
