Oil Leak
Old Feb 21, 2018 | 05:06 AM
sweitzerworks's Avatar
Oil Leak
Hey gang, I've got a leak coming from the passenger side junction of the head/block/timing cover.
The head gasket was replaced about 50k ago so I think it's good, however I'm 90% sure the old head bolts we're reused. Any chance new headbolts could solve this without pulling the head?
Let me know,
Thanks!
-Jackson
Old Feb 21, 2018 | 06:38 AM
wallytoo's Avatar
i'm not familiar enough with small block chevy engines to know whether that is a likely result. hopefully someone else is.
Old Feb 21, 2018 | 08:22 AM
Co_94_PU's Avatar
It works on the Briggs in my craftsman lawn mower..
What Wally is saying here is you didn't tell us the required information.
It is a 22r series?
Head bolts should be torqued once only.
Head gaskets should only be compressed once.
Emphasis because people reuse bolts till they bottom out or snap, as well some people change out head bolts for studs while only removing the valve cover.
You've got a leak. Get it clean and dry see how long it takes to come back and where it's coming from. Decide if it's something you can live with or want fixed.
If it's where I think you are saying, (you should have posted a picture), the not toyota fipg lost its hold and the only way to fix that is pull the head and reapply it (with quality stuff).
Old Feb 21, 2018 | 03:00 PM
It is a 22r series?
I think you're exactly right, clearly some Ultra Grey right at that junction.
It's a 22r, and the head gasket looked brand new, but I suspect the head bolts are the originals.
Bummer, I was hoping to not have to pull the head. Tell me about this Toyota goop!
Here's some pics:
Old Feb 21, 2018 | 03:30 PM
Co_94_PU's Avatar
Pull your valve cover and check the hidden fastener at the timing cover junction, also that the head bolt isn't just working its self loose there.
That's some pretty sloppy looking sealant work for sure, looks like it wasn't one clean pass and they didn't bother to wipe of the excess either.
Google Toyota fipg, more than you ever want to know about sealants and plenty of debates too. You want the black one, part number ends in 103.
rocksockdoc
Feb 21, 2013 09:36 PM
rocksockdoc
Feb 15, 2013 07:44 AM
bensyota
Aug 6, 2012 05:09 PM
Myron
Sep 26, 2006 06:24 AM
alohatiger
Sep 3, 2003 09:03 PM
