Oil leak
Old Mar 20, 2009 | 07:42 PM
jerstoy's Avatar
Oil leak
I have 1990 3.0L oil leak just replaced heads, timing belt & water pump. Leaks in front of motor. No idea where it is coming from. Any ideas?
Old Mar 20, 2009 | 07:54 PM
Junkers88's Avatar
I'd guess the front main seal. If it's like a 22re motor then the seal is under the oil pump. I don't know anything about the 3.0 so I can't say for sure.
Is it slinging the oil around in the engine compartment?
Old Mar 20, 2009 | 08:01 PM
jerstoy's Avatar
no it is just leaking. needs a new quart every 2 days of city driving.
Old Mar 20, 2009 | 08:11 PM
Junkers88's Avatar
Holy smokes!!!
Ok so the leak is at the front of the motor yes?
It's probably slinging oil all over the engine bay yes?
Take it to a car wash and blow the front of the motor off and as much as you can everywhere else. Drive it back home and crawl underneath it with it idling (neutral with the e-brake on or in park). I'm betting that you'll see oil coming out behind the crank pulley. I did some looking and as far as I can tell the oil pump on a 3.0 is behind that pulley. Your front main seal is back there also. Don't worry, it's easy as pie to change. I did mine (different motor) in about an hour.
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
