OEM Toyota ball joint part # question
Old Mar 14, 2016 | 05:19 AM
Andy A's Avatar
Anybody have a clue why Toyota uses 4 different part numbers for the ball joints, since both uppers (LH & RH) should be identical and both lowers (LH & RH) should be identical. Is it just a Toyota thing?
43360-39085, UPR BALL, LH
43350-39085, UPR BALL, RH
43340-39245, LWR BALL, LH
43330-39835, LWR BALL, RH
94 sr5 4x4 xtcab v6
Cheers
Andy
Old Mar 14, 2016 | 05:50 AM
MudHippy's Avatar
Toyota puts a left and right tag on just about everything they possibly can. Whether they're the same or not. That plus the fact that 2 of those part #s are for 2WD and 2 are for 4WD.
Case closed.
Old Mar 14, 2016 | 06:40 AM
Andy A's Avatar
MudHippy, reopen case!!!!
That is what I come up with using vehicle specific VIN at both Toyota Motor Parts, and Toyota Online Parts
Which are showing being 2wd and 4wd?
Got any #'s to share?
I want to get this stuff ordered.....
Cheers
Andy
Old Mar 14, 2016 | 07:15 AM
MudHippy's Avatar
Brain fart...sorry. That's not entirely true. They're all 4WD actually. I just wasn't seeing them all.
And I actually came up with a 5th part # too. 43330-39315 which was replaced by 43330-39835.
So...other than the lack of reasoning for the left and right thing(which I swear makes no sense...usually), that all makes perfect sense. To Toyota at least.
Old Mar 14, 2016 | 02:08 PM
Andy A's Avatar
Awesome, had me a little worried there. so at least I know I'm not crazy it's Toyota����
I didn't bother to list 43330-39315 since it was shown as being replaced by 43330-39835.
Getting ready to do a front end overhaul:
Control arm bushings
Ball joints
Idler arm
Tie rod ends
Wheel bearings
Steering knuckle bushings
Half shaft boots
Seals, dust/grease for knuckles & half shafts
Trying to use as many Toyota parts as I can so wanted to get that order right the first time!!!
Thanks for the help!!!
Cheers
Andy
Old Mar 14, 2016 | 02:33 PM
wyoming9's Avatar
Red face
What is even more Fun!!
Is the same part can have several different part #`s between years or models
