No more IM testing for Alaska! What performance mods can I do now?
Old Jan 14, 2016 | 01:53 PM
gnarbarian's Avatar
Building up a new 22RE for my 86 truck:
http://imgur.com/a/tRkUN
Here's an album of her:
http://imgur.com/a/OkOSh
It's bored 40 over, It's got a cam, 2.5" header and exhaust. The lack of IM requirements means I can pretty much do whatever.
Should I skip the Cat and go straight to a muffler?
Should I omit the EGR valve?
Should I put on a AFM from an old supra?
What else can I do?
Old Jan 14, 2016 | 02:06 PM
muddpigg's Avatar
Use upper intake and throttle body from later model 22re. Did you polish and port head? If so and funds allow send them to maxbore to be bored out. I'm not running a cat. Yes, with other mods a supra AFM makes a difference.
Old Jan 14, 2016 | 02:13 PM
gnarbarian's Avatar
Thanks muddpigg.
Haven't polished and ported the head yet. kinda on the fence as I would probably just buy a RV head if I was going that route: http://www.engnbldr.com/head-shop.html
Ommiting the EGR will make it run a bit hotter but should keep the engine more clean right?
Old Jan 14, 2016 | 02:16 PM
gnarbarian's Avatar
Almost forgot. Will any of these help?
http://www.lceperformance.com/Block-Plates-s/1447.htm
Also, define "late model 22RE"
I'm not sure what year the intake stuff is from. How can I tell?
Old Jan 14, 2016 | 02:27 PM
muddpigg's Avatar
LCE plates will work, but I always just trimmed one out of a soda can.
Late model TB and intake is after 89. Straight not turned down. Will need throttle cable too.
Polish and port with OS valves and cam is on point. I'm not a highway guy so 260 cam. Engnbldr has a third cam I found interesting and would call about for more info. But not building an engine anytime soon.
Old Jan 14, 2016 | 02:28 PM
gnarbarian's Avatar
Found these:
http://www.lceperformance.com/EGR-Bl...-p/1016039.htm
http://www.lceperformance.com/Air-In...-p/1045014.htm
Thanks again for dropping some knowledge on me!
Old Jan 14, 2016 | 03:14 PM
muddpigg's Avatar
I just trimmed a piece of soda can to fit between EGR and intake so all components are still mounted. I didn't have pair system. Good luck, gonna be an awesome motor.
SAyota
18
Mar 4, 2016 04:17 AM
ryan13
15
Feb 23, 2016 02:30 AM
LoflandJ
Jan 13, 2016 06:35 AM
Quarterpounder
Jan 11, 2016 04:57 PM
bmayer497
Jan 9, 2016 06:45 PM
