No heat
Old Dec 10, 2019 | 10:20 AM
Glen Mizer's Avatar
No heat
No heat in my 89. Heater core has never been flushed. Is that likely to be the problem?
Old Dec 10, 2019 | 10:43 AM
5 Fists's Avatar
There's a few things that could cause no heat... have you searched the forums at all? Many, many topics out there about diagnosing no heat.
I'm at work, so don't have the time to search for you right now..
The "google" option in the search function works pretty well though.
Old Dec 10, 2019 | 10:58 AM
Glen Mizer's Avatar
No heat
Thank you.
Old Dec 11, 2019 | 04:37 PM
itscrazytom's Avatar
Before you flush, check to see if your heater control valve assembly is opening and closing when you change the temperature control lever from cold to hot. Mines was seized closed due to rust.
Old Dec 11, 2019 | 04:53 PM
Old Dec 11, 2019 | 04:55 PM
Glen Mizer's Avatar
Climate control cable
That is exactly the problem. It will pull the cable when moved to cool, but will not push when moved to heat. I lubricated the cable and worked by hand. At this point it still will not push the cable when moved to heat. I'll keep working on it. Thank you.
Old Dec 11, 2019 | 04:59 PM
I pulled mines open with needle nose pliers and likely will leave it on heat until after winter. I plan to replace the assembly after deployment next year. It costs $91 on amazon.
Old Dec 12, 2019 | 11:50 AM
Aaron Borhegyi's Avatar
Did the same thing, I leave the valve on heat, but oddly enough when I turn on the ac and cool air still works great even though my valve assembly doesn't move, I think the internal vents open and close to stop the warm air possibly. I flush my heater core about once a year before winter comes.
REALGRAVEROBBER
Dec 15, 2009 11:34 PM
stupid_mud_gremlins
Mar 2, 2008 07:19 AM
MTL_4runner
79
Nov 7, 2007 06:26 AM
FSRBIKER
Nov 4, 2004 08:49 AM
NHTacoma
Feb 28, 2003 12:12 PM
