Newbie 88 4x4 pickup
Old Jul 17, 2007 | 04:33 AM
wch2106's Avatar
On a stock 88, what wheels will spin in 4 wheel drive? I recently bought the truck to drive into woods and haul out firewood, and bought a used set of 30 x 9.50's that 2 are pretty decent, and the other 2 aren't as good. I would like to place the 2 good tires on the wheels that will actually spin for max traction. Could someone please let me know. Thank you
Old Jul 17, 2007 | 05:24 AM
thook's Avatar
It doesn't really matter a whole lot. Power on open differentials will go to which ever side has the least traction. Ironic, isn't it? Once you lose traction, you lose traction.
About the best you can do in your situation is run mud tires and/or put the ones with best tread where the most load is...in the rear. The rear is what frequently bounces around and has the tendency to lose traction first.
Old Jul 17, 2007 | 05:52 AM
rdlsz24's Avatar
I agree put the tires with more traction on the back. I have an '88 with the 22RE and was hauling firewood out of my friend's woods. I had to go up a pretty steep hill with a full load and ran of out power when I was about half way up in 4-high. So after backing down the hill and putting it in 4-low I had enough power to easily make it up. Good to know in case you have any hills you have to climb
Rob
Old Jul 17, 2007 | 06:29 AM
wch2106's Avatar
The tires I bought are mud tires. I was figuring one good one on the front and one on the back, but was unsure which side drivers, or passengers.
Old Jul 17, 2007 | 06:55 AM
dropzone's Avatar
Fossilized
Put'em both in the rear and keep looking for a set of good ones for the front.
Old Jul 17, 2007 | 03:29 PM
dijlop's Avatar
yep. put em in the rear. deff. best option there.
Old Jul 18, 2007 | 12:09 AM
notanymore's Avatar
yeah if you put one good one up front and one in back the side with the crappy tires would proally be the ones spinning because they would be loosing traction the easiest, so i would say put both good ones in back
Old Jul 18, 2007 | 12:33 AM
locked stock 84's Avatar
you don't want to have miss-matched tires on an axle. that will throw off your wheel speeds and cause a traction issue and unnecessary wear on your diff.
put 'em in the rear, if they're not grabbing like you want them to then put some sand bags over the rear axle.
Old Jul 18, 2007 | 12:34 AM
Oh, and get a freakin LOCKER!!!!!!!!!!!!!!!
Old Jul 20, 2007 | 10:56 AM
wch2106's Avatar
Than you for all the help, I put the good rubber in the back, now if I could just get the brakes working. I'd be set.
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
smiley52
Jul 11, 2015 05:16 AM
Nickdigg
Jul 7, 2015 06:04 AM
zd92655
Jul 5, 2015 04:25 PM
