New member fighting a 3vze--idle, timing, mixture
Old Oct 31, 2018 | 09:03 AM
COMTB's Avatar
I had misfires and idle drops/surges when I first had the truck. After a bunch of testing it turned out my cap and rotor were shot, the contacts were sparking but not with consistent timing. Replaced those, went to time it and it was 5 degrees advanced, changed it to 12 and that helped a great deal. It still doesn't run completely correct but I think the TPS is on it's way out.
I can't help with the low idle as mine seems to run a little high at times. I see you inspected the spark and removed the entire distributor but did you take off the cap and rotor and check the contacts? I didn't see it mentioned and there's a good chance I missed it reading through quickly at work.
Old May 28, 2020 | 09:29 AM
coryleclair24's Avatar
Originally Posted by TNTye
Could be your Ecm mine had failed and some similar issues. Timing jumping around rough idle stalling
what was happening im having the same issue
Old Mar 12, 2022 | 07:34 AM
Jonesy300's Avatar
I am having the same issues currently .. have changed damn near everything with new parts... I wish I could find a problem to solve and keep from going totally crazy .. ANY advice or things that you have tried.??
jerusry
Oct 19, 2015 05:28 PM
smiley52
Jul 11, 2015 05:16 AM
bryan34w
Jul 6, 2015 05:53 PM
