New Marlin built rear 3rd member doesn't fit my 8" carrier
Old Oct 22, 2022 | 08:29 PM
Tokkelossie's Avatar
Question New Marlin built rear 3rd member doesn't fit my 8" carrier
Hey all,
I started my diff install this weekend, thinking it would be a quick job, but try as I might, I cannot get the 3rd member into my axle housing. It's a Marlin built 8" diff with ARB locker installed. My truck is a 90 v6 4wd.
The diff seems to be getting caught up on the adjusting nut on one side and the seal housing (the disk with the protruding copper air pipe) on the other. It seems like the adjusting nut is protruding further than it should, but I haven't set one of these up myself so I really don't know. AFAIK all 8" 3rds should be compatible. Could incorrect setup be the cause? Assuming the pre-load is correctly set-up, could incorrect shims cause the adjusting nut to protrude too far?
I suppose I could grind out part of my axle housing to accommodate the extra width, but i'd must rather figure out the real cause for the discrepancy here.
Old Oct 23, 2022 | 02:05 AM
wallytoo's Avatar
maybe ask a tech at marlin? they are decent with product/tech support.
Old Oct 23, 2022 | 11:16 AM
yeah I hit em up, theyre usually very responsive. Wondering if other people have run into this though, so I at least have some theory to present to them as a cause.
Old Oct 23, 2022 | 11:52 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I'm sure they'll respond, but probably not till Monday.
Old Oct 23, 2022 | 11:56 AM
Hit the crew up on the Marlin forums and someone suggested that it's fairly standard to have to grind a small part of the axle housing to clear the adjustment nut/seal housing to fit ARB lockered 8" diffs. I'll update once I've confirmed the fix for posterity.
Old Oct 23, 2022 | 02:59 PM
PickleRick81's Avatar
This same grinding or in some cases a good wack with drift and BFH is common with e locker swaps as well.
The bolt that hits the inside of the housing on the e lockers can be swapped for an hex or even better a torx bolt head with a lower profile.
Old Oct 23, 2022 | 05:19 PM
Reporting back: Success!
Ground down the four contact points (2.5 - 3.5 o'clock and 8.5 - 9.5 o'clock) minimally...maybe a mm or less...and the 3rd member slipped right in. In the process of buttoning it all up now. If it blows up on launch i'll let ya'll know
Rich_O
Jun 20, 2013 07:49 PM
Rich_O
7
Jan 3, 2012 12:54 PM
2Yotas85
Jul 28, 2010 07:18 PM
2Yotas85
Jul 25, 2010 09:50 AM
