New lower control arm bushings...anti-sieze?
Old Apr 12, 2011 | 08:53 AM
Miyoda's Avatar
After 19 years of faithful service, I am replacing my frozen lca bushings with OEM bushings from the toyota dealer. I am planning on applying anti-sieze to the nut on the adjusting cam (after I get it through the new bushing). But should I apply anti-sieze to the entire bushing itself, or maybe white lithium grease? Bear in mind I am in the rust belt.
My concern is having any kind of grease in contact with the rubber bushing causing it to prematurely break down.
Old Apr 12, 2011 | 05:31 PM
slacker's Avatar
anti-sieze for sure .. I do always anyway ..
Old Apr 12, 2011 | 06:56 PM
Miyoda's Avatar
So anti-sieze will not harm the rubber? Based on the rusted condition of the old bushings after I violently pounded the cam bolt out with hammer and punch, it seems an application of anti-sieze back in 1992 may have prolonged the effective life of the bushing.
All of the original bushings and cam bolts were frozen, the alignment shop claimed they could not align the truck. I confirmed this myself after an attempt at a "driveway" alignment.
Old Apr 22, 2011 | 09:01 AM
Miyoda's Avatar
I am following up my own thread for continuity. After getting everything apart, and getting the replacement bushings, the bushings inner sleeves are metal, which is why they froze (rusted) in the first place. Ant-sieze away.
Also, if you order replacement cam bolts, the bolts, nuts and nut cam adjusters are all separate parts. This is not apparent at all from the FSM. I am now awaiting the replacement nuts I destroyed in the removal proces.
88sasturbotoy
Jan 30, 2026 01:57 PM
nick9455649
Aug 29, 2015 02:08 AM
bobjohnson2121
Aug 18, 2015 06:17 PM
kirkrunner
Jul 27, 2015 07:59 PM
1994toyota
Jul 17, 2015 03:03 AM
