new expensive paperweights
Old Oct 7, 2009 | 04:48 PM
Beaniam's Avatar
Here's the carnage of trying to nurse a bad wheel bearing home 2 miles at 5mph.
Gouge worn in wheel hub. (already pressed in new bearing races)
Spindle destroyed.
Aisin hub destroyed.
Got so hot it burnt the paint off.
That's not grease mushed around the inside of the hub, that's what's left of the hub gear.
And the best for last... A destroyed 1.5 month old 30 spline longfield.
Just repacked the bearings when I put the longs in less than 2 months ago and they looked fine then, sweeeettt.
I've had wheel bearings go before and I've always had plenty of warning. This gave me pretty much no warning and left me 2 miles from home in the middle of the night. Driving along 45mph and suddenly the truck jerks over to the left like the brake caught. Only lasted a half a second then felt fine so I figured I'd make it home. Nope, started grinding about 5 minutes later so I started my 5 mph, pull over and dump water on the hub every 5 minutes journey the rest of the way home.
Cost me a solid axle spindle, bearings, manual hub, longfield. None of which I have spares of. Swell!
Old Oct 7, 2009 | 04:51 PM
swapped89's Avatar
crazy thats definatley some carnage
Monochrome's Avatar
Wow, that's insane! Sorry about that. Did you go wheelin recently and forget to lube the bearings after deep water, or just a random fluke? I think I'll go home and make sure mine are good...
Old Oct 7, 2009 | 04:55 PM
Beaniam's Avatar
I'm thinking this was totally random. I am pretty good at keeping up on the front end considering the cost and time I put into the SAS. I'm thinking the spindle nut backed off totally. Don't re-use the locking tab more than a couple times I guess
Old Oct 7, 2009 | 05:37 PM
BigBluePile's Avatar
Holy shnikes!!!!!!!!!! That's crazy!
Old Oct 7, 2009 | 06:19 PM
iamsuperbleeder's Avatar
ah, just needs a little duct tape...
and maybe some JB-weld...
that sucks man, but it makes for good pics
Old Oct 7, 2009 | 06:29 PM
Matt16's Avatar
DId the race or cage crack. How the heck does a blown-up bearing do that??!!
Old Oct 7, 2009 | 08:15 PM
waskillywabbit's Avatar
That sucks Justin. I got a "damaged" chromoly birf on my shop table as a creative paperweight aka beating tool.
It makes for interesting conversation.
Old Oct 8, 2009 | 04:30 AM
Beaniam's Avatar
Guessing for whatever reason the spindle lock nuts backed off totally causing the end of the axle to rest all its weight on the manual hub gear while the caliper held my wheel on. Wouldn't take long to turn that metal to mush running down the road.
Yep I have a shiny new $300 hammer.
Old Oct 8, 2009 | 02:04 PM
Volcom's Avatar
I'd send it into Bobby Long to see if he'd warranty it The look on his face would be priceless
Old Oct 8, 2009 | 04:34 PM
yoterr's Avatar
that sucks man, that some expensive stuff to be breakin....
this is what i got when i bought my toy and starting digging in....
why a screwdriver is not a good tool to put your spindle nuts on with
gouged spindle
but that only cost me a spindle from junkyard $40 wheel bearings, i think $30 and i picked up an aisin hub for $10 ( i couldent get the other one off...stupid cone washers)
Old Oct 8, 2009 | 05:21 PM
Beaniam's Avatar
at least you still have threads on your spindle lol. ordered one of the $30 used spindles from front range off road.
Old Oct 8, 2009 | 07:16 PM
86Toyrunna's Avatar
wow thats impressive. i toasted a spindle one time , but thats just pure carnage
Old Oct 8, 2009 | 07:17 PM
yoterr's Avatar
well thats a whole lot easier than sitting in the hot sun in the middle of a junkyard whaleing on a poor runners BJ's to get mah spindle
Old Oct 12, 2009 | 05:10 PM
Pyro Kennel's Avatar
at least now you will get to the broken stud....
I only have four or five at a time too.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Redeth005
Jun 28, 2018 08:16 PM
dbd6604
Oct 11, 2015 05:30 PM
White Stripe
Oct 6, 2015 10:47 AM
viesail
Sep 21, 2015 06:00 AM
