Mystery part
Old Aug 26, 2017 | 06:59 AM
torstenmeyer's Avatar
Mystery part
Hi all,
I'm doing my 2nd complete Toyota 4WD pickup restoration but this is a newer model (1987) and has unfamiliar parts. I should have taken more pictures. Does anyone know what this is? Thanks in advance.
I also note that this model doesn't have the rear drive shaft stabilizer - is that correct?
Attached Thumbnails Mystery part-20170826_062800.jpg   Mystery part-20170826_063354.jpg
Last edited by torstenmeyer; Aug 26, 2017 at 07:14 AM. Reason: Adding year model of truck
Old Aug 26, 2017 | 10:12 AM
wyoming9's Avatar
No clue what the picture is
Looks way to clean to be off something that old
Drive shaft Stabilizer ??
Old Aug 26, 2017 | 10:30 AM
I had all my bolts and brackets plated as part of the restoration project which is why it's so clean.
The stabalizer i referred to is a large rubber mounted bearing that the driveshaft or UV joint sits inside to secure the gearbox end.
Attached Thumbnails Mystery part-20170809_200700.jpg   Mystery part-20170809_201036.jpg
Old Aug 26, 2017 | 01:59 PM
dropzone's Avatar
Fossilized
do you mean the carrier bearing that was used on some long bed/ex cab 4WD's?
Old Aug 26, 2017 | 08:48 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
bolt plating
Did you do that yourself ala one of those utube videos? Or send them off?
Old Aug 27, 2017 | 12:01 AM
Green93's Avatar
I believe that part is some type of heat shield. It should bolt somewhere on the rear mount of your drivers side torsion bar. I have a part that looks near the same on my 1993 truck. Mine is in pieces as well or I could get you a pic.
Old Aug 27, 2017 | 08:16 AM
Dropzone: Yes thats exactly what I meant, I wasn't sure what it was called and obviously my truck doesn't use one.
Coopster: I had all the metalwork done by Queen City Plating WA which is not an easy or cheap process the you are in Alaska where there are few facilities. I looked at the youtube videos but didn't want to spend the time and effort as I have limited time before it has to be completed.
Green93: Thanks! That must be it. I knew it had to be a heat shield but had no idea where it was mounted. Thanks again.
Last edited by torstenmeyer; Aug 27, 2017 at 08:20 AM. Reason: spelling correction
