Mystery Oil Leak from 93 3.0 5-speed
Old Oct 19, 2014 | 02:09 PM
Squigglez's Avatar
I have a mystery oil leak coming from my engine. It looks like the oil is running down and finally falling onto the ground from the transmission. Ill attach a few pictures. Where are come places I should start my check?
This is an upside down picture of my transmission and base pan.
Old Oct 19, 2014 | 02:11 PM
anndel's Avatar
Could be from the valve cover gasket. I had the same issue though on my 22RE 4 cyl and it appeared the xmission was leaking. After replacing the gasket it stopped.
Old Oct 19, 2014 | 03:12 PM
rworegon's Avatar
Rear main seal?
Old Oct 19, 2014 | 03:51 PM
oldblue's Avatar
you need to clean everything up REAL good, then recheck for leaks.
Old Oct 26, 2014 | 08:57 AM
Squigglez's Avatar
Ok thanks guys, It ended up being the oil filter. Replaced it and it stopped leaking!
Eggslinger
Jun 8, 2019 03:32 PM
Yota.Jay
Jul 23, 2015 08:08 PM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
