Is my transmission toast?
Old Jun 9, 2017 | 07:39 PM
mchapter's Avatar
Coming home from work last Monday it sounded like a rock slide in a trash can under my cab, intermittently. The truck also had a pretty bad vibration / shimmy. I could push the clutch in and reduce the noise, after starting from a stop and shifting into second / third the noise would reoccur. 3.0 with the factory five speed transmission.
Old Jun 9, 2017 | 07:55 PM
millball's Avatar
Have you crawled under and looked at anything?? Pushed the driveshaft around, checking for loose u-joints or flange bolts???
Noises have many different potential origns.
Old Jun 9, 2017 | 09:04 PM
mchapter's Avatar
I looked under it, and nothing was dragging on the ground! I had the u joints done maybe 20k miles ago, but I should see if anything wiggles.
At this point I'm already committed to a new TRD off road, but I imagine a prospective buyer might like to know.
Old Jun 10, 2017 | 08:34 AM
dropzone's Avatar
Fossilized
Having u joints done is all well and good but in 20000 miles have you used a grease gun on them?
22 year old truck lots of bushings, transmission/TC/motor mounts etc like to fail. Change the oil in the third recently? Check d/s bolts at the pinion and output
