My rear diff is leaking
Old Oct 19, 2009 | 12:37 PM
ayoung101's Avatar
as soon as i unscrewed my breather valve, i heard the *hiss* sound of air escaping. plus the little cap was locked solid. so i'm assuming this was my problem! i cleaned up the breather valve, made sure i could blow air through it and reinstalled it. we'll see if it works! now it's on to rebuilding my starter!
Old Oct 19, 2009 | 01:10 PM
874runnersr5's Avatar
sounds good! most time its the beather, good luck with the starter!
Old Oct 19, 2009 | 03:12 PM
pruney81's Avatar
I changed the fluid in my front and rear diff using API GL-5 80W90.
that's what the FSM calls for, 10 bucks for a gallon jug at wally world
Old Oct 28, 2009 | 11:21 AM
ayoung101's Avatar
cleaning the diff breather didn't work, so now i'm changing the seal. i'm all the way down to the actual seal, thanks to some good writeups. however, that thing is rock solid. i cannot get it to come loose. any suggestions? is it gonna hurt to pound it inward to break it loose? cuz trying to pull/pry outward just isn't working and i'm worried about damaging the threads on the shaft.
Old Oct 28, 2009 | 11:28 AM
  #25
peow130's Avatar
you all just reminded me to change my diff-fluid, and check on my breather
Old Oct 28, 2009 | 12:46 PM
  #26
anthony1's Avatar
You guys should go ahead and do this so you don't have to worry about plugging it up again...
https://www.yotatech.com/forums/f129...her-mod-75747/
Old Oct 28, 2009 | 03:39 PM
  #27
ayoung101's Avatar
got everything back in one piece and filled her up! i'm so worried i did something wrong and it's gonna leak even worse now though. . . .i guess only time will tell.
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
