my latest project
Yea I know, I wish I had a lot more experience welding so that I could make it look pretty too. But so far it is all pretty solid. The last shot inside the bellmouth you are looking at the Inside of the welded material and so far I have not encountered any porosity So it should be strong. I'm going to grind the outside as well to make it look better.
But like you guys said , you fabbed it , as long as it does what you want and you created it thats cool !
You know, when I hit that deer and got out of my truck to view the damage, I was just sick, I never even went to look at the deer. In fact another motorist pulled it out of the road. plus I hit it so hard, I don't figure there was much usable meat left.
today I worked on smoothing things out
, whether death is by gun (black powder or standard), bow or motor vehicle its going home
#25
I'm still working on it
I have been working on matching the port flow with the manifold attached. I did this before I welded on the plenum so that any change that need to be made, could.
Last weekend I went to a pick-n-pull and procured a airflow sensor from a 1986 supra. this one is about 50% larger than my stock one and has "guts" that will allow for an easy swap from my old sensor. I also got the injectors from that same car. It turns out that they are the low resistance variety, but should work with the additions of some resitors to bring up the total resistance. I thoroughly cleaned and flow checked the injectors, and got them so that they have a very good spray pattern and flow within 1%-2% of each other.
Today I welded on the plenum.
#26
That is quite possibly the ugliest manifold ever (the load of welds) but i vote you keep it and dont grind it smooth... it just looks so funny
Oh and nice work with the flowbench... i wonder what kind of performance #'s it's going to give you.. i cant wait to see.
.Oh and nice work with the flowbench... i wonder what kind of performance #'s it's going to give you.. i cant wait to see.
#27
Beauty is in the eye of the beholder.
Maybe because it's like my kid, It sure looks good to me.
I've been flip-flopping over the grind smooth issue. Right now I'm inclined to grind it smooth. I'll probably change my mind two or three more times though.
One concern I have is that it'll flop. The numbers say big power, but the dynamics involved may bite me.
#29
Today I welded the flange for the throttle on
I also planed the gasket surfaces of the lower manifold which were warped by the heat from welding. The penum is going to have to be milled at the machine shop as there is to much material to be removed by hand.
#31
I'm thinking two or three more weeks.
After I figured out how much airflow increase I was getting I realized that I was going to have to upgrade that fuel delivery and injection.
as I mentioned in a previous post on this thread, I have alresdy got a oversized AFM and injectors.
I also just got a bigger fuel pump, adjustable fuel pressure regulator, and 3/8" stainless fuel line.
I also am waiting for fittings and hose that I ordered.
this week when the rest of the parts get here I am going to replace the fuel pump and plumb it up with the larger fuel line and adjustable regulator.
then likely the next week I will get the AFM and injectors on so that I can get that "dialed in" before I get the head and manifold on.
in the meantime I'll be working on the other details of the manifold, like getting the vacuum fittings and egr hooked up. and getting the head and plenum milled.
#35
Yea, I know,
While I was waiting for the webservice to get the pics uploaded I went ahead and made the post,
Well it seems there are some technical difficulties
I'll get the pics up as soon as I can.
#36
good work
nice job, i really think your inspired and very inventive.
dont sweat the welds for now, focus on functionality and someday you will have others do your welding for you. (they will line up).
otherwise, (and this is pure theory) why not install cooling vents over the welds.
it looks like its melting, but cooling vents/fins (like on differentials) have never been seen on intake or exhaust pipes yet (why not? dont we get more power from cooler motors?)
were all fallowing you on your route, and i am eager to see your rewards. (when i ported my bmw, i just did the port matching/ honing and very minimal on the intake side (it pools and suffers from dead spots if its too smooth ). the exhaust side is polished to a mirror though.
#37
There will be plenty more posts on this thread
#40
And I really hope after all this work it does run like I hope it will
Like a scalded dog
