My cruise control is on crack.
Old Oct 21, 2014 | 02:58 AM
96Goodtoy's Avatar
Cruise control shift _too much
My A340F +3.4 auto shifts early and stays in too long, coming out with a hard shift, quite often. Found a lot of threads and acknowledge my 190HP doesn't excel on hills but feel this problem is either adjustment (from wear), shift point programming or poor connections. Going to scan it and adjust it.
Glad you got yours going, had a similar problem with my parking brake switch causing it too fail but it works fine now, excepting the downshift on the slightest hill. @ 313 thousand now and the best thing I've done for the tranny is flush torque converteer et Al(7.6 qt.) ,& filter. Thinking of changing thermostat down some (hot is our problem,with transmissions and Florida)as well as flushing & coolant change. Excuse the rambling, hermits in the woods syndrome.
Last edited by 96Goodtoy; Oct 21, 2014 at 05:20 AM. Reason: Error correction_2 gal total a340f
Old Oct 24, 2014 | 05:19 AM
96Goodtoy's Avatar
Cruise shift early resolution
Thanks to Bam Zip Pow- I adjusted the control cables! Good call sir! Thanks
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Shagool22
Sep 28, 2015 07:53 PM
toyotasaurus
Sep 24, 2015 03:30 PM
