my brakes squeek...
i had this for a long time... it was this little metal clip that helps you masure how much brake pad you have left or helps get it off, i am not sure. Anyway, it was rubbing on the rotor as i drove. but it is a small piece, like a paper clip so it just made a annoying squeek.
i have replaced the pads since then, I was just saying that they can become bent and rub on things causing a squeak but mine didn't squeak when I was going under 25. Thanks for the heads up on the clips; I knew they were for something.
1uzRunner
63
Nov 10, 2018 03:58 PM
