My auto shifter is not shifting!!! HELP! PLZ!
Old Feb 26, 2008 | 08:24 AM
dirtyXplorer's Avatar
Hi Yotatech,
93' Auto, V6
Yesterday I was leaving for work and my shifter would not go into drive, or anything else. I stepped on the brake with the car running and the button on the shifter would not push in. Thankfully Toyotas have the "shift lock override" button...
Is there a linkage between the brake pedal and the shifter? I tried searching with no luck.
Thanks in advance.
Old Feb 26, 2008 | 10:50 AM
Astralplane's Avatar
Check your brake lights and/or brake fuse.
My tow light harness would blow brake light fuses constantly when it got wet.
Finally removed the harness
Old Feb 26, 2008 | 01:00 PM
CC_yota's Avatar
^X2, the same thing was happening to me last week. I was blowing fuses like crazy. I ended up having a short in the trailer light harness from it rubbing on the frame.
Old Feb 26, 2008 | 01:29 PM
I don't have any blown fuses.
Would a short in the brake lights cause the auto shifter to not go out of park?
unless I push the shift lock override button, I cant shift from Park to anything else...
Old Feb 26, 2008 | 01:40 PM
Yes, and it's a good warning.
It keeps you from driving around without brake lights.
Old Feb 26, 2008 | 01:45 PM
Could it be a bulb out too? I will check those and the fuses again tonight.
thanks for your help
Old Feb 26, 2008 | 07:51 PM
Astralplane you are awesome!
It was the "STOP" 15A fuse...
I will get a new one tomorrow and hopefully that will fix it...If not Ill be crawling around under it this weekend
Liadrin
Apr 25, 2022 02:54 PM
rusty904
Mar 27, 2017 05:20 PM
Liadrin
Sep 1, 2015 06:44 AM
Esibnitsud
Jul 21, 2015 08:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
