Modded 93 OEM Wheels?
Old May 8, 2006 | 09:56 PM
C5VetteLS1's Avatar
Originally Posted by 95RunnerSR5
is it possible to chrome spraypaint those wheels? i have the same ones
It is possible, but real chrome plating is actually cheaper. And here in So-Cal it would be about $200.00 each to plate them. Personally I wouldn't invest even 25% of that in to these wheels ... I just don't like the look. I think I'll just buy an aftermarket set for summer, I keep these for winter.
Old May 8, 2006 | 09:59 PM
C5VetteLS1's Avatar
Those would be an improvement, but they're not giving me wood either. But thanks for mentioning them. And good luck with your sale
Old May 10, 2006 | 03:56 PM
Toyopnoy's Avatar
Anyone by chance know where I can find a write-up on putting rock rings on 3rd gen wheels. I know calrockx has done it but I thought I saw a right up on that here but know I want to do it I cant find it.
Thanks, Pat
Old May 10, 2006 | 07:14 PM
brandontrek's Avatar
i still say spring for the sequoia wheels...anything worth doing is worth doing right....
https://www.yotatech.com/forums/show...993#post740993
I recenly sprayed my 7-spoke steelies with Krylon Silver Hammered Finish paint. It looked like the previous owner got it stuck in a gravel pit and spun the wheels. Stripped off much of the paint on 2 of the wheels. The result turned out pretty well, even if I DID do it myself.
Mike in AR
i like that hammered finish look...i wanted to try that on some stuff of mine that needed a new spray....do you have and pics?
Thanks, Pat
i would just like to know how to put bead locks on ANY stock rims....do you have to drill/tap the riim for the bolts?
Old May 10, 2006 | 07:18 PM
  #25
calrockx's Avatar
Thanks, Pat
i don't know if there's a writeup on it, but i can tell you the place that brucets and i had the work done is omf wheels http://www.omfperformance.com/unenhancedwheels.htm
Old May 11, 2006 | 07:28 AM
  #26
regularguy412's Avatar
Here's the finished product. Didn't take any 'before' pix.
Mike in AR
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
mussy01
Dec 13, 2016 08:20 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Massmayhem247
Jul 18, 2015 05:46 AM
