Misalignment Driveshaft?
I have a 95 4Runner with procomps 4" Lift, and at the top of the intructions it says I may need a high misalignment driveshaft because I have a V-6. Ifigured this because i have a loud humming noise coming from under the body when I release the gas pedal
, but it goes away when I re-accelerate. Please help?!
I get that vibrating too when I release the gas or put it in neutral going about 45-60mph.
I have a pickup 93 with a lift, but I don't think it's the lift. My driveshaft is in pretty bad shape anyhow.
I had to change the ujoints a while back because the noise was really bad. That pretty much took care of most of the vibrating. But the problem I described above is still there.
If you haven't done your ujoints do that....or your driveshaft might be unbalanced.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
FS[NorAtl]: Parting 93 3.0 Exta-cab 4x4,auto
ToyotaMD
Aug 17, 2018 10:16 PM
4runner, aligned, coming, drive, driveshaft, high, humming, misaligned, misalignment, misalignted, miss, noise, shaft, sound, ujoints
