Manual Locking Hub Problem
Old Aug 10, 2006 | 06:29 AM
Devilbanjo's Avatar
Hello all, I Have a question concerning my '91 4x4 Truck.
- When I go to lock or unlock my hubs it takes a lot of force to turn it to the correct position. I have strong hands and almost had to resort to using slip joint pliers as a spanner wrench. Is this normal (I have had the truck only since last november)?
I am having my doubts about this excessive need of force, especially since I noticed this past winter there might be a problem with the mechanism. During the on and off snowing conditions in the winter of southern Ohio I would leave the hubs locked in and shift in and out of 4wd as needed, but while locked in while in 2wd I would get an excessive vibration when I would slow down (similar to a stuck caliper) after driving at 55 for 10-15 minutes. I am fairly sure this is hub related as this vibration would occour even during engine braking and I could feel no heat coming from the rotors. Also to the problem remmedied itself when I unlocked the hub. hmmm.... lubrication issues perhaps?
-Karl
Old Aug 10, 2006 | 06:54 AM
ironroad9c1's Avatar
nope ,they should be pretty easy ,you need to remove em ,clean em real good ,lube em and then reinstall em.
Old Aug 10, 2006 | 06:56 AM
eric-the-red's Avatar
Here's a write-up on rebuilding them
http://www.off-road.com/toyota/tech/aisin/
Old Aug 10, 2006 | 07:27 AM
Devilbanjo's Avatar
Thanks for the info and the link guys, a rebuild is in order. I can't get my mind around the vibration issue though. I don't understand how the hub could cause it, although all of the diagnostic indicators point to it.
Old Aug 10, 2006 | 07:42 AM
brick privy's Avatar
Maybe a CV, axle, or driveshaft problem. They all turn with the hubs locked.
Yota.Jay
Jul 23, 2015 08:08 PM
rushw
Jul 18, 2015 01:46 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
ItsJustD
Jul 7, 2015 07:49 AM
