major coolant leak
Old Dec 27, 2007 | 09:37 PM
jtlinna3vze's Avatar
take a look at this link.. http://www.theengineman.com/sitebuil...s/DSC00262.JPG see the three plugs in the top(front) of the block.. right above the top one is an outlet for a coolent line.. although its at the front of the block it runs out the back.. mine would just drip all night and then gush in the day when id drive it.. just below the second plug from the top(front) is the hole for the knock sensor..
Old Dec 28, 2007 | 06:20 AM
95SASMudRunner's Avatar
ok well my engine is not that far broken down! but i will take a look and see what i can find today
Old Dec 28, 2007 | 01:30 PM
are you talking about the tube that comes up in the front right corner and its threaded into the block? if so thats not leaking, but i have only taken the intake mani off so like the fuel rails and everything are still on have i not gone deep enough? i looked today with a mirror and light and had little luck seems to be coming out of the back underneath where the temp sensor it but its not leaking there almost appears to be leaking from closer to the front of the eng like in the middle
Old Dec 29, 2007 | 06:14 AM
bump for some help
Old Dec 30, 2007 | 12:02 PM
  #25
no its a metal tube.. its got two bolts and a gasket.. in that link i showed you you can see its hole and the two holes for the bolts.. it runs out the back towards the windshield.. im looking for my papers for when i repaired it.. ill post them if i find um
Old Dec 30, 2007 | 12:09 PM
  #26
ozziesironmanoffroad's Avatar
did you check the freeze plugs on the block? a couple of mine are leaking, but at this point im not worrying about them too much, i have like 8 gallons of antifreeze, so yeah. im not losing much at all.
Old Dec 30, 2007 | 02:45 PM
  #27
no have not checked them its my understanding that freeze plugs = pull the engine?!? hoping that someone corrects me in this
Old Dec 30, 2007 | 03:17 PM
  #28
James Dean's Avatar
http://www.jamesdeancreations.com/4r...ct.htm#By-Pass
If it's the by-pass hose at the back, with the right hose and a couple tools (long needle nose) you can change it in about 15-20 minutes. Be careful of the vacuum port switch next to it. It will probably be dried out and break easily.
Old Dec 30, 2007 | 03:35 PM
  #29
that was cracked and replaced as mentioned earlier in the thread, but i still have a leak
Old Dec 30, 2007 | 04:02 PM
  #30
KevinInSac's Avatar
I feel your pain. I'm burning coolant pretty quick, but I have pressure in all six. I love trying to find mystery leaks...
Think there might be a crack some where on the motor?
Old Dec 31, 2007 | 09:19 AM
  #31
well leak number two is found! bad news is its a small crack in the metal line that connects to the heater hose, its completely unreachable!!! its shoved between the firewall, engine block and exhaust crossover. i would hate to pull the engine to fix a coolant leak! any suggestions?
Old Dec 31, 2007 | 09:21 AM
  #32
<edit> circled wrong thing pic doesn't show but its a metal tube that y's at the top one large one smaller diam hose connect. but you get the idea
Old Dec 31, 2007 | 09:30 AM
  #33
mattches's Avatar
The place you speak of, you know shoved way back under everything?
Yes it is a pita to get to. But you do not need to pull your entire motor. But you do have to pull your intake plenum and intake manifold to get to it so that you can replace the entire unit. It is the crossover pipe from engine water jacket to the heater lines and thermal switches. It runs underneath your intake manifold to a hookup at the top of the water jacket for the motor.
It really is not to terrible to get to, just be sure that you have marked all connections and hoses and have gotten very familiar with the routing before removing the plenum. Even if you haven't it is not to hard to reverse engineer it.
Good Luck.
PS once you are there please take care to replace all your coolant hoses connecting to that thing. Or else murphys law dictates that one of them will fail as soon as you get it back together.
Old Dec 31, 2007 | 09:35 AM
  #34
mt_goat's Avatar
Hey that workshop and engine looks just like mine. Never mind, I see you got some better advice from Mattches.
Old Dec 31, 2007 | 09:55 AM
  #35
yea i figured it be easier to steal ur photo than to take my eng out to take my own.... here is yet another stolen photo that shows the correct location of the leak (the green dot)
but sounds like you guys already knew that so i guess its time to start taking stuff apart...
Old Dec 31, 2007 | 09:57 AM
  #36
i have the air intake chamber off so now pull the manifold and ill be good? ordered the $200 worth of parts from the stealership and wont be here till thurs so looks like this is getting put on hold, how bad is it to leave the eng w/o coolant its suppose to hit the mid 20's this week at night...
Old Dec 31, 2007 | 10:28 AM
  #37
mt_goat's Avatar
Do you mean you drained the coolant or that you have it full of water w/o antifreeze? Big difference there.
Old Dec 31, 2007 | 10:36 AM
  #38
its empty had just water in it to find leak then drained it, the intake air chamber is off and the water bypass outlet are both off as well
Old Dec 31, 2007 | 12:12 PM
  #39
thats the tube ive been talking about all along!!! score one for me!! just pull all of the intake.. if you want have the tube welded or replaced.. new gaskets.. and your all set..
Old Dec 31, 2007 | 12:32 PM
  #40
mt_goat's Avatar
Hmmm, that is a little scary. I'd a least open the block drains and pull the t-stat to get as much water out as possible. I'd also be concerned about the heater core if it has water in it because its hard to drain the heater core. You can flush it with some antifreeze mix.
