machined down flywheel clutch plate
Old Sep 10, 2011 | 01:10 PM
dashiling's Avatar
So i had my flywheel resurfaced for a recent clutch replacement. Now the hydraulic clutch actuator that engages the clutch arm need a longer rod! I've got all the adjustments maxed out and still i just barely engage the clutch. Can you get an aftermarket rod that will make up the difference? I'm thinking of monkey rigging something to either extend the arm towards the rod , or extend the rod with an added... something maybe a cap headed nut. Any ideas? (22re PU)
Old Sep 10, 2011 | 03:56 PM
eric924run's Avatar
I think you have a differnt problem. they should have only machined the flywheel a few thousandths. maybe your master cyl or slave cyl is leaking. or the pivot ball is worn down. the rod between the fork and the slave cyl should not need adjustment
Old Sep 11, 2011 | 12:25 PM
wyoming9's Avatar
Smile
Could very well be the wrong throw out bearing or clutch slave cylinder if both were replaced
Seeing this way to often wrong parts packed in correct box
he's gone
7
Dec 3, 2019 07:08 AM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
smithyboy69
Nov 28, 2015 04:13 PM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
