lubing my diffs and other chassis parts
Old May 7, 2008 | 06:35 PM
machine23's Avatar
94 3.slow runner.....tried to loosen the plug on my front and rear diffs. seems impossible to me. any suggestions? i would rather do it myself instead of paying someone
Old May 7, 2008 | 06:59 PM
MMA_Alex's Avatar
heat/penetrating oil, and more leverage. make sure you get the fill plug out before you drain em
Old May 7, 2008 | 07:15 PM
tc's Avatar
tc
x2 on fill plug first!
I have had to weld a bar on mine before to be able to get enough torque on it ...
Old May 7, 2008 | 07:29 PM
ROCK LIZARD's Avatar
X3 of removing fill plug FIRST. Use a 6 point socket so you don't round off the plug. Make sure the socket is the correct size. Use a hammer to give the socket handle or break-over bar a couple of sharp whacks. Take your time and it will come off. They can be very tight if they have never been removed. Use same method on drain plug. No reason you can't do this yourself.
Old May 9, 2008 | 06:40 PM
Crawdad's Avatar
If you can't get the drain plug out (mine was seized in place), you can always buy a pump and pump the stuff out from the fill plug. It's not as effective, but it's close.
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
msane99
Jul 17, 2015 10:13 AM
TokyoD23
Jul 12, 2015 06:01 AM
