Looking for a Toyota genius!
Old Mar 16, 2008 | 01:48 PM
SEAIRESCUE's Avatar
Two things need to be done. One is a compression test. Secondly is a vacuum gage reading if you can get it to idle. Personally, its either a head gasket or bad AFM. When the AFM goes bad, they tend to run extremely rich known as the limp home mode. As suggested, check the AFM door to make sure it swings freely. If the smoke is white at start and lots of condensate dripping out the pipe, its the head gasket. Blue smoke and fuel smell is a fuel related problem. Black oil smell smoke is bad rings and burning oil.
Hope this helps.
Old Mar 18, 2008 | 08:45 AM
mojo4x420's Avatar
Vrey important to have the TPS adjusted correctly.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
