Locking gas door
Old Feb 24, 2008 | 06:54 PM
91Toyota's Avatar
Locking gas door
My lock is broken. You can hardly stick the key in and when you do you CAN NOT turn it. It was that way when I bought it. Is there anyway I can get a replacement? Do I have to use that key...or can I get a lock made for my key?
Thanks
Old Feb 24, 2008 | 07:13 PM
Jay351's Avatar
Get a lock out of a junker truck, and have the lock re-keyed to your ignition key.
Old Feb 24, 2008 | 07:54 PM
MMA_Alex's Avatar
Or just pull the lock.
On mine I've found that it works fine when I use it regularly, but when I dont use it for awhile it tends to get sticky, and I need to jiggle the key around to get it to unlock.
Old Feb 24, 2008 | 07:58 PM
fillsrunner4's Avatar
could try some graphite and see if it loosens it up a bit. It will be expensive im guessing to re-key a lock to work with your ignition key
Old Feb 24, 2008 | 08:07 PM
881stGenRunner's Avatar
just spray it with wd-40 or some lubricant and see what happens first. My door locks were also kinda stuck until i lubed them up.
Old Feb 24, 2008 | 08:12 PM
Jay351's Avatar
22 bucks to get a used lock cylinder re-keyed to my ignition key ( drivers side door)
Old Feb 24, 2008 | 08:16 PM
Thats a lot less than I thought it would be
Old Feb 24, 2008 | 08:19 PM
Jay351's Avatar
cheaper then a lock from the stealer!
Old Feb 24, 2008 | 08:20 PM
TOYOTA 1's Avatar
mine is junk to it flops open when i take left hand turns lol
Old Feb 24, 2008 | 08:24 PM
ya the stealer is a rip but sometimes the best place to go.
toyota 1 you and others could always add magnets to make it stay shut. I know it makes it easy for thieves but thats not a huge risk one would think
Old Feb 24, 2008 | 08:31 PM
Jay351's Avatar
With gas as expensive as it is, I don't trust the tweakers. I am going to get a locking gas cap too.
Old Feb 24, 2008 | 08:34 PM
TOYOTA 1's Avatar
haha thats a good idea!
Old Feb 24, 2008 | 08:36 PM
TOYOTA 1's Avatar
no crap tweakers suk they steal anything
Old Feb 24, 2008 | 10:37 PM
standardbyker88's Avatar
mine crapped out. had to prybar it open at the gas station. got it, then just took the lock clip out and threw them in a drawer at home. might fix it. perfer it without. when i get a new bed (this one is hammered) im gonna shave it and flip it inside the bed.
Old Feb 25, 2008 | 06:42 AM
91Toyota's Avatar
I didn't know they could do that! I will have to get a lock and have them rekey it then. Thanks!
Mine does swing out on left hand turns...lol
Old Feb 25, 2008 | 06:45 AM
Victor's Avatar
graphite is the way to go but I usually spray a rust eater type lube in mine. My rear gate lock is sticky since I don't use it much as is the passenger side lock on the front door.
Old Feb 25, 2008 | 06:50 AM
dirtoyboy's Avatar
I have locking doors and/or cylinders with keys...PM if you are interested...
-Collier
Old Feb 25, 2008 | 05:06 PM
91Toyota's Avatar
I tried a bunch of stuff but couldn't get it to budge. I have decided to just get it rekey'd. Much cheaper!
-Collier
Sorry, but I am going to have to pass. My friend just rolled his 87 Toyota so I am going to grab the lock cylinder...maybe...or just find one in a junk yard. Thanks though!
Old Feb 25, 2008 | 05:41 PM
MMA_Alex's Avatar
you can probably get a locksmith to rebuild the one you have just as easily
Old Feb 25, 2008 | 06:13 PM
91Toyota's Avatar
maybe...it sounds like it is broken inside. I took a hammer and hammered the key in to get it in. I could kind of get it out but I had to use vice grips.
